So why FM?
Well . . . that is a very good question. In highschool I attempted to transmit music through amplitude modulation with a cheap laser pointer and the noise was unbearable. Turns out that ambient light created a sort of feedback that made my project very inefficient. If the lights weren't out, the reciever wouldn't play my signal. Even with the lights out, only one song was audible--"Hey Soul Sister" by Train. So the purpose of this project was to fix that bug. We wanted to be able to send music in the middle of the day as clear as possible. With FM, we could set up a series of oscillations that would fix that. The circuit forms a free-running FM oscillator/modulator operating at twice the operating output frequency. This is the core of the modulator. The output is linear ramping voltage of either positive or negative slope.
And why an IR LED?
We originally planned to use a laser pointer and a photodiode. However, it turned out that we bought the wrong photodiode--we had a blue photodiode receiving red laser light. We realized this at the very last minute and had to change to parts we already had--an IR phototransistor paired with an IR LED. If you want to use a laser pointer and a correct photodiode, you can simply replace these components.
Either way, this was the Intro and I hope you will enjoy building this project. It's a bit challenging but I will try to make it as simple as possible.
Remove these ads by
Signing UpStep 1Parts list for Modulator/Transmitter
For the transmitter:
Capacitors
.1uF ………………………….5
4.7uF (25V)………………2
270pF……………………….1
1uF (35v) ………..……….2
.001uF………………….…..1
.01uF…………………….….1
10uF (25v)…………………1
100uF (16v)………………1
Diodes
1N5817 (Schottky rectifier)……….2
IR LED………………………………………….1
1N914…………………………………………1
Resistors
10k…………………………………………….5
2.7M……………………………………….…1
270k…………………………………………..2
100k…………………………………………..4
2.2k………………………………..………….1
33k…………………………………………….1
560 Ohm………………………………..….1
240 Ohm……………………………….…..1
2 Ohm………………………………………..1
ICs
LF347 (Quad JFET op-amp)……………………1
CD4069 (Hex CMOS inverter)………………………..1
CD4013 (Dual CMOS D flip-flop)…………………….1
TC1411 (HS driver)(Digikey TC1411CPA)………..1
LM317 (Voltage regulator)…………………….……..1
Potentiometers (trimmers)
100k (trimpot)……………………….…..1
10k (trimpot)………………………….…..1
500 Ohm (trimpot)……………………..1
you also need a Breadboard and many connectors/wires
I suggest you purchase the ICs through Digikey.com, The Pots and diodes through Radioshack, and the rest through Jameco. Doing this, my modulater cost me about $45-60. I bought most parts in exccess. I suggest Part no. 20812 for breadboard. You can also use a regular breadboard if you wish to work under a budget.
I've done this with lasers... but IR would be cheaper and invisible.
Will try this.
BTW - what really grabbed my attention at first was that I thought it was a picture of my equipment! I have the same exact power supply and auto ranging fluke meter! haha... was a little weird at first glance :)
