Sending Sms If Smoke Is Detected (Arduino+GSM SIM900A
39,527
48
6
Published
Introduction: Sending Sms If Smoke Is Detected (Arduino+GSM SIM900A
About: Teen highschooler from Udaipur,India. Technology Enthusiast. Been there done that !
Hii everyone
In my first instructable I will be making a gas alarm which sends message to the user if pollution is detected.
Step 1: Materials Required
(1) Arduino Uno board (or any Arduino board)
(2) GSM shield (Personally recommended GSM SIM900A).
(3) Jumper Cables
(4) 10 K resistor
(5) Breadboard
(6) MQ 135 gas sensor
Step 2: Making Connections (GSM MODULE TO ARDUINO)
First of all connect the Tx of gsm module to pin #2 of arduino , Rx to pin#3 and make the grounds of both the apparatus common. And don't forget to power the gsm shield with a 12v external power source while running your device.
Step 3: Making Connections (between Sensor and Arduino)
make connections as shown in pic and TREAT YHE SIDE OF SENSOR WITH"MQ135" WRITTEN AS TOP.
and choose analog pin A0.( to match with code otherwise you have to change it)
Step 4: Testing Time
firstly we will run code attached so that we can see readings of sensor in normal and polluted environment on serial monitor.
Note down the values in both the cases.( we can make the environment polluted by lighting incense stick in front of sensor :p)
Step 5: Final Testing
Use the noted values to edit the final code attached and change the cellphone number in code and write the code in arduino.
Open serial monitor and wait
serial monitor will show "status OK" and soon will send sms to the cellphone.
Video soon would be published.
    • Clocks Contest
      Clocks Contest
    • Planter Challenge
      Planter Challenge
    • Woodworking Contest
      Woodworking Contest
    Hello Friends,
    How to download any things in this website..plz tell i don't know ..it ask upgrade premium but i don't have any account in the bank so i can't upgrade it
    6 Comments
    Hello my friend, tried to compile the code and I get a bunch of errors. I am new at Arduino so please help me with the libraries (I think there is the problem)
    See below error codes
    Arduino: 1.8.4 (Windows 7), Board: "Arduino/Genuino Uno"
    In file included from C:\Program Files\Arduino\libraries\GSM\src/GSM.h:46:0,
    from C:\Users\user\Desktop\Ardruino\sms_again\sms_again.ino:1:
    C:\Program Files\Arduino\libraries\GSM\src/GSM3ShieldV1BandManagement.h:49:125: warning: 'typedef' was ignored in this declaration
    typedef enum GSM3GSMBand {UNDEFINED, EGSM_MODE, DCS_MODE, PCS_MODE, EGSM_DCS_MODE, GSM850_PCS_MODE, GSM850_EGSM_DCS_PCS_MODE};
    C:\Users\user\Desktop\Ardruino\sms_again\sms_again.ino: In function 'void setup()':
    C:\Users\user\Desktop\Ardruino\sms_again\sms_again.ino:36:21: warning: invalid conversion from 'int' to 'char*' [-fpermissive]
    if (gsm.begin(2400)){
    In file included from C:\Program Files\Arduino\libraries\GSM\src/GSM.h:45:0,
    C:\Program Files\Arduino\libraries\GSM\src/GSM3ShieldV1AccessProvider.h:80:24: note: initializing argument 1 of 'virtual GSM3_NetworkStatus_t GSM3ShieldV1AccessProvider::begin(char*, bool, bool)'
    GSM3_NetworkStatus_t begin(char* pin=0,bool restart=true, bool synchronous=true);
    C:\Users\user\Desktop\Ardruino\sms_again\sms_again.ino:46:97: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
    (sms.SendSMS("+919461022454", "RJ27 CB 3**9 Pollution Level Exceeding , Attention Required "));
    libraries\SoftwareSerial\SoftwareSerial.cpp.o (symbol from plugin): In function `SoftwareSerial::read()':
    (.text+0x0): multiple definition of `__vector_3'
    libraries\GSM\GSM3SoftSerial.cpp.o (symbol from plugin):(.text+0x0): first defined here
    (.text+0x0): multiple definition of `__vector_5'
    (.text+0x0): multiple definition of `__vector_4'
    C:\Users\user\AppData\Local\Temp\ccEiHlnU.ltrans1.ltrans.o: In function `openCommand':
    C:\Program Files\Arduino\libraries\GSM\src/GSM3ShieldV1ModemCore.cpp:184: undefined reference to `gsm'
    C:\Users\user\AppData\Local\Temp\ccEiHlnU.ltrans1.ltrans.o: In function `begin':
    C:\Program Files\Arduino\libraries\GSM\src/GSM3ShieldV1AccessProvider.cpp:92: undefined reference to `gsm'
    C:\Users\user\AppData\Local\Temp\ccEiHlnU.ltrans1.ltrans.o:C:\Program Files\Arduino\libraries\GSM\src/GSM3ShieldV1AccessProvider.cpp:92: more undefined references to `gsm' follow
    C:\Users\user\AppData\Local\Temp\ccEiHlnU.ltrans1.ltrans.o: In function `setup':
    C:\Users\user\Desktop\Ardruino\sms_again/sms_again.ino:46: undefined reference to `SMSGSM::SendSMS(char*, char*)'
    C:\Users\user\AppData\Local\Temp\ccEiHlnU.ltrans1.ltrans.o: In function `loop':
    C:\Users\user\Desktop\Ardruino\sms_again/sms_again.ino:57: undefined reference to `gsm'
    C:\Users\user\Desktop\Ardruino\sms_again/sms_again.ino:57: undefined reference to `SIMCOM900::readSMS(char*, int, char*, int)'
    collect2.exe: error: ld returned 1 exit status
    Multiple libraries were found for "GSM.h"
    Used: C:\Program Files\Arduino\libraries\GSM
    Not used: C:\Users\user\Documents\Arduino\libraries\ITEADLIB_Arduino_SIMCom-master
    exit status 1
    Error compiling for board Arduino/Genuino Uno.
    This report would have more information with
    "Show verbose output during compilation"
    option enabled in File -> Preferences.
    can we replace PIR sensor by Ultrasonic sensor
    why is the sensor reading being taken in the setup() when it ( as far as I know) runs only once.
    what all is happening inside loop()?
    why is the baud rate 2400?
    Gsm module used works best on baud rate 2400 for purpose (refer datasheet)
    Sensor reading is in setup so that i can avoid multiple sending of SMSs (obivously i dont want to go broke :p) by changing the code a little you can get what you want (probably i was very lazy to do so)
    And for inside loop, we can also read the messages received on sim on serial monitor.this is for that :)
    Hope that helps
    Sorry for late reply ....
