I bought these off a friend, they're 8 yrs old but instantly became my favorite cans. They developed an issue where sound would cut or reduce volume in the left driver, this was temporarily fixed by jiggling the connector where it meets the driver until sound restored. I decided to fix the connector once and for all.
I searched the net and found many others with the same problem, a common flaw in an otherwise flawless and indestructible pair of headphones.
The common suggestion was to replace the cable (Min $50 for a Sennheiser 1.5m steel cable) or replace the driver (even more expensive and unnecessary for this issue).
My fix costs $0, works perfectly, and all you need is a soldering iron and some solder.
Remove these ads by
Signing UpStep 1What you need.
To open the capsule and get to the internal connectors (diagnose only) :
-Small flat head screwdriver
For the cable connector fix:
-Needlenose pliers
-Soldering Iron
-Solder
Thanks a lot for the top advice
