loading
Hello! This instructable is out of service.
I2C is bvilt to support multiple adresses using the same two lines. you can hook up multiple sensors and lcd or what ever you want on the same pins. i dont remember how many, it is limited, but probably more than you would hook up to one microcontroller anyways. you define each devices adress in your code. <br><br>thank you for your instructable. lots of good ideas. thought you would like to know you could use your I2C module for your lcd also.
<p>Thank you for this information. I am working on it now. I hope it will not make long delays on communications with both connected. Because this LCD I2C module works different, it also needs a different library. If it works than there will be a lot of pins for other sensors.</p>
About This Instructable
514views
9favorites
License:
Bio: Exploring, searching, hacking... is my life. I am working on radiation, high voltage, programming, 3d drawing, hacking, music and...
More by Kutluhan:Sens3Box Mini Fume Extractor Nokia 5228-5230 Touchscreen Replacement
Add instructable to:
