Sensor Tutorial HC-SR04 Linkit One
Published
Introduction: Sensor Tutorial HC-SR04 Linkit One
About: Thank you instructables!!
In this tutorial I will make a simple project using hc-sr04 and linkit one board giving you an idea about using it.The L.E.D glows whenever an object comes in between the specified distance.Her is a video of it working:-
Step 1: Things Requires
We need :-
  1. Linkit one board
  2. Jumper wires
  3. Hc-Sr04 ultrasonic distance sensor
  4. Battery
  5. USB cord
  6. L.E.D
Step 2: Pin Configuration
Insert all jumper wires one by one in the 4 pins of sensor,2 terminals of L.E.D .
  1. Connect -ve terminal of L.E.D to gnd
  2. Connect +ve terminal of L.E.D to digital pin
  3. echo to 12
  4. trig to 13
  5. vcc to +5
  6. gnd to gnd
Step 3: Code
#define trigPin 13
#define echoPin 12 #define led 11
void setup() { Serial.begin (9600); pinMode(trigPin, OUTPUT); pinMode(echoPin, INPUT); pinMode(led, OUTPUT);
void loop() { long duration, distance; digitalWrite(trigPin, LOW); delayMicroseconds(2); digitalWrite(trigPin, HIGH);
delayMicroseconds(10); digitalWrite(trigPin, LOW); duration = pulseIn(echoPin, HIGH); distance = (duration/2) / 29.1; if (distance < 50) { digitalWrite(led,HIGH);
}else { digitalWrite(led,LOW); } if (distance >= 200 || distance <= 0){ Serial.println("Out of range"); } else { Serial.print(distance); Serial.println(" cm"); } delay(800); }
Step 4: Done!
I hope this will help you to understand and modify the code to make more interesting instructables using the
    • Planter Challenge
      Planter Challenge
    • Make it Move Contest
    • Oil Contest
      Oil Contest
    2 Comments
