3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Separate Hydrogen and Oxygen from Water Through Electrolysis
Step 3Water and Salt
Water and Salt
Water alone is not a very good conductor. You need to add some sort of electrolyte. Regular old table salt works fine. Add as much as will dissolve into the water, and don't worry about it if there is some sitting on the bottom, it really doesn't matter. Pour this salt/water solution into your med. container, and also fill your 1 or 2 gas collecting containers
6 comments
Mar 14, 2011. 10:16 AMmDey says:
*IMPORTANT QUESTION*
I'm doing this as a science project - can I do this with SEAWATER?
Mar 29, 2011. 9:01 PMFRED MAXEY says:
we did it all the time with sea water, on a submarine, but you still have to distill the water and add a di agent.
FM
Mar 24, 2011. 11:57 AMbluke1 says:
Sadly the electrolysis of sea water does not yield hydrogen or oxygen. Instead, it yields chlorine gas. (deadly poisonous).
Although known to scientists for a long time, this fact became common knowledge during the second world war.
If a battery powered submarine hull was damaged (holed) by enemy action or accident while submerged, sea water would enter the hull of the submarine. If it reached the terminals of the motor batteries, chlorine gas would be given off in large quantities which would then kill any crew that came into contact with it. (there is no 'fresh air' in a submerged submarine.) Nasty stuff.
At the time nearly all submarines of all navies used large batteries to power the submarine underwater. these batteries could be recharged by the main (diesel) engines when the sub surfaced at night for that purpose and to renew the air supply for the crew to breathe.
Jul 16, 2011. 7:56 PMjluke says:
at sea, yes there would be a huge amount of chlorine. when the decomposition is completed with salt, the result is chlorine gas and some remaining sodium i believe
Mar 25, 2011. 9:28 AMmDey says:
Oh well. Gonna try it anyway! :)
Mar 25, 2011. 12:21 PMbluke1 says:
Good luck.
Jun 9, 2008. 7:50 PMtitan001 says:
I thought I'd mention that Salt is probably a bad alternative for an electrolyte, however cheap it may be. The chemical composition of salt is NaCl, or Sodium Chloride. If you're electrolyzing the water, the salt will separate as well, and although in relatively small quantities, you are releasing Chlorine Gas (Mustard Gas) into the air. Chlorine gas will recombine with the water in your eyes and mouth, turning into Hydrochloric Acid, which burns no matter how small the dose. A better alternative would be Baking Soda, if you can find some.
May 24, 2009. 5:37 PMvestie says:
You might want to check your facts... Chlorine =! Mustard Gas.
Jun 29, 2008. 8:20 PMtercero says:
Actually you produce sodium hypochlorite..(Javex) which is dissolved in water. Not to argue, but I and couple thousand other people have a salt water pool system (Intex) and Electrolysis happens all of the time, every day (for 4 hours in my pool) and I'm still living. So...not quite accurate.
Sep 8, 2009. 10:44 AMR4NS0M says:
lol...not mustard gas, chlorine gas ~maybe in minute amounts. the more dominant byproduct that will result (and still in small quantity on this scale) would be, depending on the amount of Nacl used and other factors, Na-OH which is more or less dilute Sodium Hydroxide or lye. hehehe fun stuff! let's make some soap!
Jun 29, 2008. 7:33 PMWyle_E says:
Chlorine, nasty as it is, isn't mustard gas. That's a different (and deadlier) beastie, a class of organic sulfides that were used as chemical warfare agents in WWI. It's still not a good idea to electrolyze sodium chloride, unless you want chlorine and chlorine compounds. Sodium bicarbonate is just as easy to come by, and yields hydrogen and oxygen.
Sep 29, 2009. 7:19 PManarchysk8 says:
wyle is corect baking soda or sodium bicarbonate is much easier on you as well as easier to mix with the water being that its finer particles require less mixing and as far as the mustard gas thing goes Sulfur mustard is the organic compound described with the formula (ClCH2CH2)2S. In the Depretz method, mustard gas is synthesized by treating sulfur dichloride with ethylene whit sulfur being the main and most important part has no part in this little experiment neither does ethylene so there are no adverse affects to using salt but i would still use baking soda as it produces hydrogen with water
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
16
Author:hooloovoo33
Buildin' not buyin'
