Step 5The Electrodes
iImage Information
Now take the two electrodes leading from your power source. The hydrogen will form on the positive electrode, and the oxygen on the negative. If you don't know which is which, turn on the power source and stick the electrodes in the water. The one with more bubbles is the hydrogen. Now stick the electrode underneath the gas collecting container. (turn off the power first) If you're having trouble making the gas collecting container stay up, and the electrode stay in the right place, tape it. Thats what I do anyway.
Cl2 is highly toxic to the lungs - and has immediate consequences.
Prolonged exposure to CO causes CO poisoning, where CO bonds with your red blood cells, and the can no longer take in oxygen. This will go away after a while (weeks) if you don't get it so badly that you die. ie. better than CL2
NaOH is the safest because it produces no harmful byproducts.
However, if you are in a position where you can choose salts, go for a sulfate (as mentioned below) because it does not take part in any of the reactions, so you end up with just H2 and O2.
Sulfuric acid is a good one, and it can be found in off-the-shelf cleaning products (drain cleaner?)
***Always add ACID to WATER when diluting.***
Adding water to a container with pure or near pure Sulfuric acid is a bit like dropping a Mint in a soda bottle it will boil quite violently and go everywhere..
The water molecule is held together by the electromagnetic attraction between these ions. When electricity is introduced to water through two electrodes, a cathode (negative) and an anode (positive), these ions are attracted to the opposite charged electrode. Therefore the positively charged hydrogen ions will collect on the cathode and the negatively charged oxygen will collect on the anode.
I have same question: Cathode is negative and makes hydrogen, please
explain how is positively charged hydrogen ions will collect on the cathode
and negatively charged oxygen will collect on the anode?
So the diagram is correct? Is it the way we need to connect to battery as
your diagram showed?
Thanks.
If you want to test it, ignite it. Oxygen is an oxydizer, it will not burn (unless it is under pressure).
