Step 6Thats it!
The electrodes do corrode if you don't have graphite, its pretty gross, but i don't think its dangerous. (don't quote me)
Here is a video of it bubbling:
All Steps Viewing
Can I hook up a motor to the driveshaft of an engine to generate the electricity instead of a battery?
Does hydrogen require oxygen to burn?
How many volts are required to create a decent amount of hydrogen? What contributes to how fast the electrolisys process is: volts, amps, or watts?
http://en.wikipedia.org/wiki/Chromium_toxicity
The only SAFE metal is the Nobel one Platinum! By the way if you use the heat from your engine you can make more power via 1st by using several sterling engines then on the low heat end power then using by the same steam turbine and a radiator even more power then keep on going down till itscool water by using a fan.
As for the hard drive disks. Depends what you want, more plates wil almost always produce more gas, but even just one will work. I never even use plates to be honest, i use 2 bolts dipping into the water from the top. I run about five of them, I dont know what my production rate is, but I'm happy with the results, running my camry 4cyl at 42mpg (27mpg orig)
viral
Can't figure it out...
viral
Try it on a lawn mower, generator, or some other small gas engine.
I'm waiting for somebody to try it on diesel engines. I get 18mpg with my power stroke, but i would like 25 about 30% better!
Get it HERE
sixminus4is5 , the Ford Corperation uses the same engine and fuel as I, and they dont get that so called ping. Mabey you need to look it up and gain some insite from the same people I sell a percentage of my Patent rights to. look under new ford ICE cars and mabey you'll have a little more understanding from now on.
