Server Cabinet to Food Dehydrator, Arduino Controlled
7,105
35
7
Posted in FoodCanning-and-preserves
Introduction: Server Cabinet to Food Dehydrator, Arduino Controlled
About: just have to figure out how all these things go together....
We needed to make a bunch of raw food and often that means dehydrating.  To accomplish this we found a server cabinet and turned it into a dehydrator.
This was a pretty simple project and produces a lot of food storage.
Specifications
- Dehydrate at around 115F
- good temperature control (top, middle, and bottom sensors)
- A lot of air movement
- 750 watt George Forman Grill powered
Step 1: Parts and Pices
Major Pieces
Server Cabinet
George Forman Grill (good will or some similar heating device)
Commercial Kitchen Rack and trays
5 volt Power Supply (I used one from an old PC like this)
qty(3) Server Cabinet Fans
2" of rigid insulation around the cabinet
Controls
Arduino Pro by Sparkfun (although any Arduino will work)
LCD Button Shield by Adafruit or Sparkfun
Dallas Temperature Sensors, qty(3) Sparfkun, Adafruit
5Volt relay by Sparkfun or ebay
Notes:
The relay has to handle 120volts and 10 amps depending on the george foreman grill you get. Just read the specs.
Step 2: Air Flow and Heat Control
The back of the unit has a piece of wood that creates a 3" plenum all the way to the bottom.
Hot air is warmed by the heater, rises to the top of the cabinet, and is blown by qty(3) fans into the plenum.  Air is blown down the backside of the unit and exits next to the heater. (see picture).
In order to help moderate the radiant heat transfer we added tiles above the grill. (see picture).
The front door does not seal to well. This allows quite a bit of fresh air to circulate into the cabinet which is key as moisture evaporating from the food needs to escape.
Step 3: Wiring
Wiring:
1) LCD Shield and Arduino need 5 volts.
2) wire 5 volts, ground, and digital control pin to George Forman Grill relay
3) Wire Server Fans always ON
4) Wire Dallas Temperature Sensors. One towards the top of the unit, one in the middle, and one at the bottom to get an average temperature across the cabinet.
Step 4: Programming
The program is attached below.  It is a pretty simple program using the Dallas Temperature one-wire library and the LCD Button Shield library.
Dallas Temperature one-wire tutorial is here.
LCD Shield tutorial is here
The three temperature sensors are averaged and the grill is turned ON and OFF based on the temperature setpoint.
    • Science of Cooking
      Science of Cooking
    • Space Challenge
      Space Challenge
    • Spotless Contest
      Spotless Contest
    7 Comments
    nearly two years later, what would you have done different? How does it work? I'm about to build it!
    yes, there were issues with mold... so it would be good to add a humidistat so that you can determine the humidity and keep it under .... say 70% or whatever the threshold. If the humidity is consistently too high, you would want the ability to trigger more fans ON to exhaust the humid air. Maybe play around with some different heat sources too. Maybe an oil filled flat plate design that can output 1500watts for capacity as needed.
    http://www.lowes.com/pd_361901-29280-EE-8068+W_0__?productId=3445988&cm_mmc
    where was the mold growing? Were your temperatures reaching where you wanted them? Would altering the air current make a difference? Maybe if I had vents on the top and fan blowing up from the bottom? or moved the fans to the very top of the plenum?
    Thanks!
    E
    So I've never done arduino before, but I'm about to get started shortly. My question is why did you test for the readings on the sensors of less than 40 degrees? Does less than 40 indicate an error with the sensors somehow?
    Hello, would you have a wiring diagram and if i was wanting the temps in degrees Celsius how would i go about this
    Great project cant wait to build one smilar
    Really enjoyed this, where did you get your serer cabinet?
    It was from an estate sale. Good luck!
