3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
ServerBot - for serving food and drinks
  • Ready to Serve
  • Rear View
I believe I have created a robot that's functional, helpful, entertaining, whimsical AND simply amazing.
The ServerBot. Built upon an iRobot Create.
A robot with the ability to move reliably between any room in the house while carrying a payload, in our case, a serving tray on top. The ServerBot has a much greater potential with other tasks of moving laundry and such. The elderly could appreciate a ServerBot to help transport just about anything around the house.
You are in the Kitchen with a tray of popcorn and drinks for movie night. You have more to take out but can't carry everything in one load (or you are physically disabled and are unable to carry everything). Just push the ServerBot CALL button and within a minute or two ServerBot arrives to assist you. Place your items on top and press the button on the ServerBot for the room you want it to deliver its payload to. Off it goes.
It knows its way around, carrys things for you, talks to you, and won't bump into things.
This is a Live Working Model that we are actively using at my house. My goal with the Create has always been to make something USEFUL out of it. So far this is IT. This project will continue to evolve. We have plans for interchangable bodies, one of which will be a big Ice-Bucket so it can roam around with cold drinks at a party. As-is, it can roam around at a party to deliver drinks and horsdevours and return to the kitchen for re-stocking.
The ServerBot can be covered and re-covered in different fabrics to match your decor or a party theme. This covering is held on with scotch-tape, I'd suggest something less tacky. Ha!
The current ServerBot has evolved over a period of time so I don't have good pictures of it's construction. I am now documenting the building of the next one in more detail so keep watching.
This bot is not as complicated as it may look with all the following technical mumbo-jumbo. If you can solder, then you can build the circuits without any trouble. You don't have to use the same body I did, anything will work (a cardboard box would do just fine). Very few parts are required and all parts are readily available online or at your hardware store.
Step 1Video
Video
43 comments
1-40 of 43next »
Sep 14, 2007. 10:03 PMMr. Rig It says:
Cool, makes me thirsty just watching it. Good job
Feb 18, 2012. 6:49 PMlove de robots says:
yah
Jan 27, 2010. 2:50 PMraykholo says:
Several weeks ago,I started working on a similar infrared beacon, however using an astable 555 oscillating at a 600hz frequency, running off 3 volts.  It works great, but a problem that I am having is the range of the IR Signal...
Can you tell me about how far this beacon can reach out?  (IR can be seen through a camera btw)  and if you have any ideas to extend the range...?   I will try mine again using some different IR Leds in case that was the issue, but any input you can provide would also be helpful.
Thanks
Dec 30, 2009. 5:29 PMnazculi says:
Looks cool, too bad I have a split level
Sep 1, 2007. 12:11 PMred_metallic says:
How does it handle stairs? ;-) Seriously, this is an amazingly useful idea. We don't have a house where we could get much used out of it but anyone in a ranch or slab home sure could. A+!
Jun 15, 2009. 10:55 PMFreddyA says:
Very impresive work. What updates have you made on it? Also, you mentioned other project for serverbot. Anything you can let out of the bag? Good job, I'm going to give it a shot with a dirt dog and I would appreciate all the hand holding you can give.
Oct 11, 2008. 7:44 PMcmgd says:
That is probably the best instructable i've ever seen. I'm so gunna buy this once i get the money, 1 more year, im only 13 years old =P
Feb 10, 2008. 12:36 PMdarth2o says:
Yeah, VEX robotic kit! I have one of those. We need some VEX instructables.
Sep 11, 2008. 8:41 AMIW5 Industries says:
i agree darth2o, i have a vex myself and have made a servebot that grabs and delivers drinks.
Jun 28, 2008. 5:49 AMDerin says:
no 256 dollars min
did you notice the coincidence?
Jul 4, 2008. 11:29 AMDerin says:
238 will also do
the coincidence was 256 is a main number on binary
Jul 10, 2008. 6:20 AMDerin says:
NOW PULLED DOWN TO $195!
Jul 10, 2008. 6:21 AMDerin says:
MAN IM DOWN TO $165!
Jul 10, 2008. 6:22 AMDerin says:
$130 is the cheapest I can get it
Dec 30, 2007. 3:20 AM_Akira_ says:
sheesh...thats cool! wish i had thought of it...this stuff is FAR above me but still its SO cool.
Jul 2, 2008. 10:55 AMmr.dr.prof.joel says:
and lazy
Jul 2, 2008. 11:46 AMmr.dr.prof.joel says:
but what if it where to be suspended from the cealing
Jul 2, 2008. 11:54 AMmr.dr.prof.joel says:
heres what might work. sory if its a bit slopy
May 27, 2008. 1:58 PMtony stark says:
I'm going to put a entertainment system on it and make it voice activated!
Nov 18, 2007. 11:44 AMItsTheHobbs says:
these projects are wwaaayyyyy above me, but still an amazingly awesome job!!!!
Nov 14, 2007. 10:50 AMMercat says:
Awesome! The first thing i thought of for modding the body was R2D2 and Jabba's fancy drink-server. =P
Thanks for posting this! Very inspiring.
Sep 11, 2007. 8:18 PMpppoootttzzz says:
when i saw the title i thought "put drinks on roomba" Guess i wasn't too far off
Sep 6, 2007. 3:34 PMkaren608 says:
Really neat. Why did you make it that tall? I noticed the water in glass moving a bit and maybe if you had a rubber mat it would keep things from accidently sliding off. I'd like one, then I wouldn't have to deliver everything by hand to my husband!
Mar 4, 2008. 4:40 PMShut Up Now says:
about it not moving fast.. you could make a tray for it that had cupholders and then make some sort of lid that can cover the tops of the glasses to prevent spillage..? im sure something like that could work to get faster speed out of it.
Sep 4, 2007. 8:03 AMrockyt says:
how long will the motors driving the wheels last? Seems like they were getting a bit bogged down by the weight of the tube, and the items its carrying.
Sep 2, 2007. 9:06 PMmoomoocows says:
where do you get the basic bot
Sep 3, 2007. 10:10 AMmoomoocows says:
thanx
Aug 31, 2007. 2:20 PMiairj84 says:
That's pretty cool... I would never make one but it would be cool to see one in action
Aug 31, 2007. 2:44 PMJames (pseudo-geek) says:
you are brilliant. I think I might do this sometime in the future, but right now I know little about anything more than basic circuitry.....I'm gonig to favorite this and rate it +
Sep 1, 2007. 2:59 PMJames (pseudo-geek) says:
but you need a microprocessor, right? I have no idea how to use those things.
1-40 of 43next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:JoeCreate
