Step 11IR Beacon
The Create does a pretty good job with Distance calculations based on it's wheel encoders. But there is still a little slippage here and there to cause it to get skewed over time. Something was necessary to re-orient the Create every so often so these Beacons (after testing with RFID) were the easiest to implement. With one beacon to cross somewhere on the X axis, and the Docking Station somwhere on the Y axis, the Create has been able to traverse the same path endlessly without intervention.
I put a 1" piece of Drip Tubing on the LED to narrow the beam to increase the Creates distance accuracy.
So far, this beacon has been running off 2 AA batteries for several weeks straight. I'm sure it could be tweaked much more for optimal run-time.
This could be a perfect lead-beacon for the Robo-Bellhop. Easier to build and smaller to conceal in a belt or strap. It works great with Adaptive Mapping as a way to occasionally recalibrate it's position.
Can you tell me about how far this beacon can reach out? (IR can be seen through a camera btw) and if you have any ideas to extend the range...? I will try mine again using some different IR Leds in case that was the issue, but any input you can provide would also be helpful.
Thanks
