Servo Motor + Potentiometer + Arduino: Potentiometer-Controlled Servo
3,112
12
Published
Introduction: Servo Motor + Potentiometer + Arduino: Potentiometer-Controlled Servo
About: I love to make projects based on microcontrollers including robots and IoT technologies. Absolutely, truly, madly, deeply in love with planes. I also dabble in the art of Origami and play chess in my spare ...
Hello World!
I'm Unicorn Clockworks, here with another project. Today, we will be controlling a servo motor's angle using a potentiometer knob, where the angle of the servo motor corresponds to the rotational displacement of the potentiometer with a linear correlation.
Step 1: Materials
  • Arduino or Arduino-compatible microcontroller
  • Servo Motor
  • Potentiometer
  • Jumper Wires
  • [Optional] Breadboard
Step 2: Potentiometer Connections
1a
  • Connect the Grey wire from the VCC pin of the potentiometer (pin 1) to the 3.3V pin on the Arduino.
  • Connect the Green wire from the signal wire of the potentiometer (pin 2) to pin A0 on the Arduino.
  • Connect the Purple wire from the ground wire of the potentiometer (pin 3) to the GND pin on the Arduino
Step 3: Servo Connections
2a
  • Connect the Blue wire from the signal pin of the servo motor (orange-coloured wire) to pin 3 on the Arduino
  • Connect the Red wire from the VCC pin of the servo motor (red-coloured wire) to the 5V pin on the Arduino
  • Connect the Black wire from the ground pin of the servo motor (black-coloured wire) to the GND pin on the Arduino
Step 4: Code
//include the servo library
#include <Servo.h>
//create a servo object
Servo servo1;
// declare the pins to which the servo and potentiometer is connected.
const int servoPin = 3;
const int pot = 0;
int potValue;
void setup() {
  //associate servo1 to pin 9 on the Arduino 101
  servo1.attach(servoPin);
void loop() {
  // put your main code here, to run repeatedly:
    potValue = analogRead (pot);
    // linearly scale the value of the sevo output from the 0 to 1023 range of the potentiometer
    // to the angle limits by the servo which is 0 to 180 degrees
    potValue = map(potValue, 0, 1023, 0, 180);
    // record the now-adjusted value of the potentiometer to the servo motor
    servo1.write(potValue);
Step 5: It Works!
Turn the knob of the potentiometer and watch the servo motor move along with it.
Enjoy your build and have fun!
Unicorn ClockWorks Out!
  • Woodworking Contest
    Woodworking Contest
  • Clocks Contest
    Clocks Contest
  • Make it Move Contest
I shared this with my class as they built the same project. Thanks for the help
