Servo Motor Sweep Mode Interfacing With Mediatek Linkit One Board
236
4
Posted
Introduction: Servo Motor Sweep Mode Interfacing With Mediatek Linkit One Board
A servomotor is a rotary actuator or linear actuator that allows for precise control of angular or linear position, velocity and acceleration.[1] It consists of a suitable motor coupled to a sensor for position feedback. It also requires a relatively sophisticated controller, often a dedicated module designed specifically for use with servomotors.
Servomotors are not a specific class of motor although the term servomotor is often used to refer to a motor suitable for use in a closed-loop control system.
In this iNstructable,You will be able To Interface Servo Motor with Mediatek Linkit one Board
Step 1: What We Need
  • 5 kgf.cm Torque Servo Motor
  • Mediatek Linkit One Board
  • Connecting wires
  • USB cable
Step 2: Connections
Connect the black wire from the servo to the GND pin on the Linkit one Board.Connect the red wire from the servo to the +5V pin on the Board.Connect the yellow or white wire from the servo to a digital pin 9 on the Board
Step 3: Code,Compile and Run
Upload the Code and You are Ready To go!!!!!
Thanks for watching
    • Spotless Contest
      Spotless Contest
    • Space Challenge
      Space Challenge
    • Trash to Treasure
      Trash to Treasure
