3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Servo Squirter - USB Water Gun
A USB controlled servo water gun. Great for firing at unsuspecting passers by, or keeping people with annoying questions at bay.
This project is a small water pump mounted on top of a servo for directional firing. The whole thing is driven by a microcontroller, and controlled from your keyboard over USB.
To see more of our projects and free video tutorials check out our website http://www.nerdkits.com
Step 1Gather the Materials
This project is microcontroller based. Other than the ATmega168 microcontroller included in the USB NerdKit. For this project we used the following:
1 Hobby Servo, Hitec HS-50
1 Low voltage piston water pump
1 Small n-channel MOSFET, 2N7000
1 comment
Feb 24, 2009. 11:27 AMNerdz says:
I like this idea. I saw on make a couple days ago about someone hacking one of those USB missile launcher things, and now Ive been wanting to do the same with a automatic airsoft gun (one of the cheap electric ones for less than $20), of course, without the USB. It would be awesome if you could use a PIR sensor to track a target or even cheaper would be to use a IR transistor and a IR LED. For those who use a PIC, setting the CPP and PWM registers will work also. For a 4 Mhz clock the lowest Freq you can use is 250Hz, so set your duty cycle appropriately. hmm I wonder if this can be done with A Nerf Gun..but Nerf Guns require pumping..Hmm
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:nerdkits
