Set-Up a Slackline
Set-Up a Slackline
Slack lining is a very fun and challenging "sport" that requires a lot of skill. However the cheapest slack line "kits" available are around fifty bucks, i made this one for about half of that. This instructable will show you how to set up your own slackline.
Step 1Supplies
supplies
Here is what you will need. I got all of the supplies from REI, but i am sure there are many other places that carry these things.
Materials
1 inch tubular webbing- (at least) 70 feet
carabiners - 5
carpet (1ft. by 3-5ft.)
also needed:
2 trees, poles, or any two VERY sturdy upright objects
78 comments
1-40 of 78next »
Aug 8, 2011. 10:26 PMCUclimbing says:
Whats this? just use a friction knot with two biners. Much easier.
Jun 11, 2011. 7:29 PMmclayton says:
Be more helpful. You don't explain things well enough, so I don't understand
Aug 4, 2010. 11:25 AMwoody558 says:
An easier way (but probably not instructables-worthy) is to just buy a ratchet strap and wrap one end around the tree and attach the other end to an anchor around the tree.  It makes it very easy to tighten, too.  They only cost about $15.
Apr 19, 2011. 6:11 AMsk3lton says:
I use a ratchet for my slackline it is very quick and easy to set up but i don't trust it for long/high lines
Mar 7, 2011. 5:24 AMMarsh says:
Rather than using 4 carabiners here, use three and thread the piece you currently have going through the 4th biner back underneath the strap at the 2nd biner. Tension alone will hold the line secure and you'll be able to get it a lot tighter.
Oct 28, 2010. 9:30 AMkmix says:
I use line lockers in my kit, they are rappelling rings, solid cast aluminum rings about 1.5 inch diameter. using these with a carabiner allows you to put 0 knots in your main line and it gives you a perfectly flat surface to walk. They are available from REI.
Aug 3, 2010. 1:21 PMwoody558 says:
Will this webbing work? http://www.countrybrookdesign.com/2-Inch-25-YDS-Heavy-Black/Webbing-Polypro-Polyproplene/2-Inch-Heavy/Black-p5129583.html Also, is there an advantage of having the four-carabiner tensioning system versus a two-carabiner system?
Jun 9, 2010. 12:51 AMflamekiller says:
A worthwhile consideration on this setup: these carabiners are tri-loaded. In a shorter line as in this Instructable, that's probably not a problem, but consider other methods when rigging a longer line. Carabiners are rated to be loaded axially on their major axis (along the spine from end to end) and a tri-loaded 'biner will fail at a lower load. Again, probably not a problem here.
Jul 5, 2010. 8:50 AMadamcgreenberg says:
These are loaded in the same way you would rig an anchor for climbing. the biner is only being loaded at two points even though it is connected to three things.
May 15, 2010. 7:17 PMwoody558 says:
How long did it take before you could walk without help?
It seems like you would need immense concentration and superior balance to walk on one of these.
May 14, 2010. 3:15 PMwoody558 says:
How is this $25?
5 good biners cost $25 (total) + 70 feet of webbing costs $25 =
$50
This costs just as much as a kit.
May 15, 2010. 3:03 PMwoody558 says:
How do you make it with 3 biners?
May 8, 2010. 6:09 AMwoody558 says:
Will these carabiners work?
www.academy.com/index.php
May 7, 2010. 10:06 AMwoody558 says:
What if the anchors slip on the tree?
Jun 23, 2008. 12:39 PMMKohen says:
Hey I'm thinking about going into slacklining, but I've got some questions... Do the carabiners have to be the screw-lock type? Can they just open and close? Also, what type of webbing and carabiners did you get off REI? I don't want to spend too much money...
Jun 27, 2008. 2:19 PMfizil says:
I would think the non-pulley side wouldn't need any biners. I would put a bend in the rope and tie a double over hand knot so that there is a nonslipping loop in the end. Put that end around the tree and fee the free standing side through then do the pulley stuff on the other side.
Apr 19, 2010. 5:54 AMlasersage says:
a knot/bend would actually be better than what is shown in step 5. Crabs should NEVER be 3 way loaded like the picture shows. It should've been girth hitched round the tree then crabbed to the line to keep the crab aligned.
This ible totally takes me back, I bought a load of webbing and did it this way. Used it once or twice and really liked it, then my girlfriend bought me a proper ratcheting line for my birthday. Way more convenient.
Totally try it out this way on the cheap, but buying a decent line makes life so much easier in the longrun.
Just had my first slackline of the year on saturday. Came back pleasingly easily. Can get from one end to the other, turn, bounce, even tried doing some poi whilst walking. Can't do any mad flips yet though  :)
Apr 23, 2010. 1:16 AMlasersage says:
I thought I did until I owned a ratchet.
I was convinced I needed the extra pull available through the pulley method, but you don't actually need tree felling power, just nice'n tight.
Hence why I went with the pulley system first, but having owned the ratchet system I wouldn't go back. Quick and easy and definitely less hardware. I had 5 crabs, but the biggest problem with it was I had way too much webbing and didn't want to cut it. Made setting it up tedious. I should've faced facts that I'm not as awesome as I'd like to be, cut it, then had a lot easier time. Bet I would've liked it more then  :)
Each to there own I figure.
Jun 28, 2008. 10:12 AMfizil says:
oh yeah, forgot about getting the webbing flat.
Jun 25, 2008. 12:35 PMMKohen says:
the three carabiner one would be useful. How did you get 5 of the ones on the website for $9? wouldnt it be more like $25?
Apr 18, 2010. 9:36 PMnbail79 says:
 Do the carabiners have to be locking?
Apr 22, 2010. 9:50 PMnbail79 says:
Awesome, thanks. I went ahead and got some oval non locking biners. Great ible by the way. It came right when i was thinking about buying a kit. Oh how my mind did change.
Apr 20, 2010. 9:48 PMwolf123450 says:
With my slackline, I store it by folding it over 4 times and tying it into a daisychain, and then hooking the carabiners to either end of that, and the same with the anchor loops, and it just slings over the shoulder.  Then you've only got to worry about carrying the carpet pieces in your arms.
Nice instructable.
Apr 18, 2010. 11:56 AMgreatpanda says:
 This appears to be a ringbolt hitch/lark's head/cow hitch, in a clove hitch one of the bights is turned the other way.  It's the right knot for this though, since it's in a sling anyway.
Jul 21, 2009. 11:48 AMJoshBittner says:
The carabiner system is nice, but it gets hard to tension the line when it is very long. I use the Charger 40 Kit from Freeflow Lines. (http://www.freeflowlines.com) Very nice kit, super easy to set up, and easy to tension.
Apr 26, 2009. 7:39 AMviridiscomis says:
of course, he could have gotten even this system really tight if he used a travelling pulley (ie another biner hitched onto the pullcord). I just tried one yesterday, the thing was amazing, and then you can add biners like that ad infinitum (if it weren't for friction), there's amazing potential with those things.
Apr 24, 2007. 3:24 PMMyself says:
A video clip or some diagrams would really help with that last complicated step. It looks like a good way to take up slack in a strap, and it's a technique I should know, but it's a bit hard to follow.
May 30, 2007. 2:40 AMzoink says:
How he got it tight enough will three yanks I have no idea.
1-40 of 78next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
12
Author:admanrocks
my name is Adam!
