iImage Information
Slack lining is a very fun and challenging "sport" that requires a lot of skill. However the cheapest slack line "kits" available are around fifty bucks, i made this one for about half of that. This instructable will show you how to set up your own slackline.
Step 1Supplies
iImage Information
Here is what you will need. I got all of the supplies from REI, but i am sure there are many other places that carry these things.
Materials
1 inch tubular webbing- (at least) 70 feet
carabiners - 5
carpet (1ft. by 3-5ft.)
also needed:
2 trees, poles, or any two VERY sturdy upright objects
It seems like you would need immense concentration and superior balance to walk on one of these.
anyone can get good at slacklining, that's why it's so great.
5 good biners cost $25 (total) + 70 feet of webbing costs $25 =
$50
This costs just as much as a kit.
haha, well let me say this.
Since making this a few years back i have realized that 5 biners is quit excessive. you really only need 3.
and yeah, webbing would be 25 dollars.
sooooo that's 35.
I really dislike the kits though, like those gibbon lines, those suck, i would not recommend them.
you can also double the webbing through, which allows for better MA and the friction holds the webbing tight, so you don't really need to tie it off or worry about it slipping before you do.
I really like this system.
www.academy.com/index.php
you need biners that can carry a load.
I would recommend these one's
www.rei.com/product/662847
you can set up a line for not a whole lot:
webbing - - 32 cents a foot (1 inch tubular military spec)
carabiners- $9 these
there is a way to set up a line using only 3 or 3 biners, let me know if you want to see how to do that.
but you could probably get it for 30 bucks
This ible totally takes me back, I bought a load of webbing and did it this way. Used it once or twice and really liked it, then my girlfriend bought me a proper ratcheting line for my birthday. Way more convenient.
Totally try it out this way on the cheap, but buying a decent line makes life so much easier in the longrun.
Just had my first slackline of the year on saturday. Came back pleasingly easily. Can get from one end to the other, turn, bounce, even tried doing some poi whilst walking. Can't do any mad flips yet though :)
I've always preffereed this method to the racheting systems.
A slackline is a simple thing, no need for unneccesary bels and whistles.
I tried one of those Gibbon one's with the 2 inch webbing the other day.
That's funky. I spose I'm a litle bit of a sentimentalist
I was convinced I needed the extra pull available through the pulley method, but you don't actually need tree felling power, just nice'n tight.
Hence why I went with the pulley system first, but having owned the ratchet system I wouldn't go back. Quick and easy and definitely less hardware. I had 5 crabs, but the biggest problem with it was I had way too much webbing and didn't want to cut it. Made setting it up tedious. I should've faced facts that I'm not as awesome as I'd like to be, cut it, then had a lot easier time. Bet I would've liked it more then :)
Each to there own I figure.
I'd reccomend the $5, oval, non locking one's though.
It's easier and cheaper to use non-locking biners.
Just make sure that you're using legit climbing biners, meant to hold large loads. (climbing one's)
Nice instructable.
