Setting Up Octoprint Web Interface for 3d Printer on Cubietruck
2,785
13
8
Posted in Technology3D-Printing
Introduction: Setting Up Octoprint Web Interface for 3d Printer on Cubietruck
It would be interesting to be able to manage your 3d printer without having a cable attached to your PC. Most people have tried it out using raspberry pi. Initially, I bought this bought for some other projects but it has been lying around for quite sometime. This board has 2 USB 2.0, VGA, HDMI, RS232, ethernet, SATA, SPDIF and some GPIO ports. So, I thought why not try out the Octoprint. Let's get started.
Step 1: Step 1: Setting Up Cubietruck
The cubietruck is a dual core ARM board by default the wifi is disabled. If you are using the ethernet instead, the wifi setup is optional. In order to perform the setup, you need a monitor and a keyboard. The cubietruck supports both VGA and HDMI. However, these options are done when selecting the image for this board.
Wifi:
1. Login to lubuntu: linaro/linaro
2. add bcmdhd to /etc/modules (need to reboot)
3. Add nameserver 8.8.8.8 to /etc/resolv.conf ( without this, the system will be connected to the wifi but no internet access)
4. Reboot
Step 2: Step 2: Adding External Harddisk
The image is loaded into the internal NAND RAM. To speed things up and add more space to the system, I have connected a 2.5" harddisk to the SATA port on-board. The system files can be moved to the harddisk by performing the following steps:
Moving the rootfs to harddisk:
1. sudo su - root --> change to root user
2. mkdir /tmp/1 /tmp/target
3. mount /dev/nandb /tmp/1
4.fdisk -l -> to locate your drive, sda? sdb?
5.fdisk /dev/sda
4. mkfs.ext4 /dev/sda1
5. mount /dev/sda1 /tmp/target
6. (cd /tmp/1; tar --backup -c *) |tar -C /tmp/target -xv
7. mount /dev/nanda /mnt/
8. vi /mnt/uEnv.txt (Change root=/dev/sda1)
9. sync
10. umount /mnt
11. reboot
Step 3: Step 3: Installing Octoprint
Install subversion at get pyserial for the Ramps 1.4 to connect with Cubietruck:
1. sudo apt-get install subversion
2. svn checkout svn://svn.code.sf.net/p/pyserial/code/trunk pyserial-code cd pyserial-code cd pyserial python setup.py build sudo python setup.py install
Install Python related packages and clone the Octoprint devel source for the latest development.
1. cd ~
2. sudo apt-get install python-pip python-dev git git clone https://github.com/foosel/OctoPrint.git
3. cd OctoPrint
4. git pull git checkout devel sudo python setup.py install
After that, ./run to run the Octoprint server. It will be hosted in 0.0.0.0:5000 locally on the Cubietruck. You can also access it through other devices by replacing the 0.0.0.0 with the Cubietruck IP.
Step 4: Step 4: Adding Webcam
Additionally, you can also add webcam to stream the video of the print. Install the related packages and clone mjpg-streamer:
1. cd ~
2. sudo apt-get install subversion libjpeg8-dev imagemagick libav-tools cmake
3. git clone https://github.com/jacksonliam/mjpg-streamer.git
4. cd mjpg-streamer/mjpg-streamer-experimental
5.make
To test out the video stream: ./mjpg_streamer -i "./input_uvc.so -y" -o "./output_http.so -w ./www" You should be able to get the life feed from your USB webcam using port 8080 with the Cubietruck IP or 0.0.0.0 locally in Cubietruck.
Step 5: Finally: Attach Your Printer to Cubietruck Usb
Now your printer can be access locally through the web interface.
    • Spotless Contest
      Spotless Contest
    • Microcontroller Contest
    • Space Challenge
      Space Challenge
    8 Comments
    Got a Problem i can´t solve. everything is fine until sthe installation of octoprint. there i got an error Processing netaddr-0.7.19.tar.gz
    Writing /tmp/easy_install-ENjJvA/netaddr-0.7.19/setup.cfg
    Running netaddr-0.7.19/setup.py -q bdist_egg --dist-dir /tmp/easy_install-ENjJvA/netaddr-0.7.19/egg-dist-tmp-VXnJfn
    warning: no files found matching 'release.py'
    error: Setup script exited with error: No space left on device
    but there is about 118GB space free
    Did you run in normal user or sudo mode? One problem could be your root is full.
    All done. Prolem was a size of /tmp about 20mb. And another way like the tutorial:
    01.) Login to lubuntu: linaro/linaro
    02.) sudo vi /etc/modules (add bcmdhd)
    03.) sudo vi /etc/resolv.conf (Add nameserver 8.8.8.8)
    04. sudo vi /etc/apt/sources.list
    change to deb http://old-releases.ubuntu.com/ubuntu/ raring main universe
    deb-src http://old-releases.ubuntu.com/ubuntu/ raring main universe
    05.) sudo vi /etc/fstab (change the size to about 200mb)
    06.) Reboot
    07.) sudo apt-get update
    08.) sudo apt-get upgrade
    09.) sudo su - root
    10.) mkdir /tmp/1 /tmp/target
    11.) mount /dev/nandb /tmp/1
    12.) fdisk -l
    13.) mkfs.ext4 /dev/sda1
    14.) mount /dev/sda1 /tmp/target
    15.) (cd /tmp/1; tar --backup -c *) |tar -C /tmp/target -xv
    16.) mount /dev/nanda /mnt/
    17.) vi /mnt/uEnv.txt (Change root=/dev/sda1)
    18.) sync
    19.) umount /mnt
    20.) reboot
    21.) sudo apt-get install python-pip python-dev git
    22.) sudo apt-get install subversion
    23.) svn checkout svn://svn.code.sf.net/p/pyserial/code/trunk pyserial-code
    24.) cd pyserial-code/pyserial
    25.) python setup.py build
    26.) sudo python setup.py install
    27.) cd ~
    28.) git clone https://github.com/foosel/OctoPrint.git
    29.) cd OctoPrint
    30.) git pull git checkout devel sudo python setup.py install
    31.) octoprint serve
    awesome, many thanks
    Really amazing.You like literally developed a base platform. From here on you can add so much additional functionality which is limitless.Thank you for taking time to create this.You did a great Job
    Very nice. Thanks for sharing this tutorial, I think a lot of people will find it useful!
    Thanks for the compliment ;)
