Setting Up a Laptop to a Projector
1,493
8
8
Posted in TechnologyLaptops
Introduction: Setting Up a Laptop to a Projector
Paper handouts are a thing of the past! Meetings have now incorporated the use of visual presentations to help engage employees and to keep their attention throughout the entire presentation. By using a projector during a meeting, less time is wasted on preparing handouts. The use of a projector will also help to decrease the cost of materials used for printing such as, paper, ink, and binding materials.
You will need the following items before you begin:
1. A projector
2. A projector remote
3. A projection screen
4. A laptop
5. A laptop power cord
6. A network cable
7. A power strip (if not close to an outlet)
By the end of this tutorial, you will be able to successfully hook up your laptop to a projector. This process The will reduce the time and energy needed to create hand outs.
Disclaimer - Presentations are intended for educational purposes only and do not replace independent professional judgment. Statements of fact and opinions expressed are those of the creator. The video provided within this demonstration is for convenience only. I do not sponsor, endorse or otherwise approve any of the equipment used. While every effort and care is taken in preparing the content of this site, Kelly Biggert disclaims all warranties, express or implied, as to the accuracy of the information in any of the content. It also (to the extent permitted by law) shall not be liable for any losses or damages arising from the use of, or reliance on, the information on this demonstration. It is also not liable for any losses or damages arising from the use of, or reliance on this demonstration, or the internet generally.
Step 1: Lower Your Projector Screen
Lower your projection screen by either pushing a button or manually pulling on a cord. A projection screen can come in many different shapes and sizes. For this demonstration, my facility purchased an automatic screen that lowers from the ceiling by pushing a button. If a screen is not available, your images can be displayed on a neutral wall. However, if you choose to display on a wall instead of a screen, you may notice the image is not as clear.
Step 2: Plug in Your Power Strip
Begin by plugging in your power strip cord into an outlet. Depending on where your outlets are in your meeting area, a power strip may be necessary. By using a power strip,not only will it give you more ability to station your equipment throughout the room, but it will give you the ability to plug in additional devices needed for your presentation, such as an additional computer or speakers.
Step 3: Attaching Your Computer Power Cord
It is very important to have your computer fully charged before beginning a presentation. To ensure that you will never run out of battery, plug your computer's power cord to the power strip. You will notice that the power cord on this computer attaches to the back of the computer.
Step 4: Logging Into Your Computer
Once your computer has power you must turn it on. Once the start up menu has ran its programming, you will be required to log in with your username and password. If you do not know your credentials, your Information Technology Department will be able to help you. If you are using your personal computer, contact the manufacturer of your computer for additional help.
Step 5: Attach the Network Cord
Your network cord should be attached to the back of your computer. This outlet may be on either side of your computer as well, depending on the manufacturer. In this demonstration, a Dell computer was used. This network cord is connected from your computer to your projector. If this cord is not properly connected, your images will not be displayed on your projection screen.
Step 6: Turn on Your Projector
The projector I used was attached to the ceiling. To turn this unit on, I simply used the projector's remote and pressed the "ON" button. If your projector is not attached to a location out of your reach, you can press the "ON" button directly on the projector itself. It may take anywhere between 1-3 minutes for your projector to display an image on the screen, so be patient.
Step 7: The Image Is Displayed on the Screen
If you have followed each step, your image on your computer screen should be the same as is on your projection screen.
Step 8: Putting It All Together
In this video, I demonstrate step-by-step instructions on how to hook up your laptop to a projector.
Thank you for taking time to watch my Instructable. I hope by following these steps it will reduce time and money spent on preparing handouts for your meetings.
    • Spotless Contest
      Spotless Contest
    • Trash to Treasure
      Trash to Treasure
    • Microcontroller Contest
    8 Comments
    thanks this system make things much easy
    Very helpful thanks.
    A network cable is used for connecting to a network, that is then usually connected to the internet, they are not made for transmitting video. What you are most likely using is a VGA cable which is made for transmitting video. Also, not to discredit how well made and thorough this instructable is, because it is very in depth. Why is it featured? It is obviously made for those who are computer illiterate but I had known the featured page to show new and extraordinary instructables, not tutorials on how to turn on a computer and plug a video cable in.
    there are 4 mode on a computer for external display on windows:
    projector only, compute only, duplicate, extend
    you can access these setting by pressing (start+p)
    there is more than that when connecting a projector to a laptop you also need to:
    set correct screen resolution
    adjust: brightness and contrast on your projector
    keystone the projector (unless it is a fixed projector then it is probably already done)
    hope this helped
    Yolo Pigeon :)
    that is a vga cable you are using not a network cable here is a vga cable
    and here is a standard network cable (RJ-45)
    Great instructable.
    One thing it is probably good to mention - give yourself plenty of time to set up at the start, and to tidy up at the end. It's embarrassing to have people assembling in your conference room and you're still trying to set up because you only got there five minutes beforehand.
    I've run into a lot of people that don't know how to use them, this is a good intro guide. :)
