Setting Up an Active DNS to Point to a Raspberry Pi 2 With a Web Server on It
Published
Introduction: Setting Up an Active DNS to Point to a Raspberry Pi 2 With a Web Server on It
This image describes the traffic flow of using an Active DNS service! Active DNS services are also refereed to as Manages DNS services as well
Step 1: Choose a Active DNS Service to Use
This link will provide a list of Active DNS providers
https://en.wikipedia.org/wiki/List_of_managed_DNS_...
I choose Dyn.
Step 2: How to Find You WAN IP Address to Use With the Active DNS Service
To find the WAN IP Address
1st. Open your Web browser. Log in to the router that connects to the Internet by entering its local IP address.
2nd.The username, password and other information will be found in the documentation for the router Or online or whatever you set the login/password up to be when you set up the router
3rd. Find the WAN IP in the router's configuration.
4th. Use the WAN IP Address when setting up the Active DNS service.
I flashed a open source firmware called gargoyle on to the router i am using. A standard router will have the same information and abilities I will be talking about.
Step 3: Setting Up the Active DNS Updating on the Router
Setting up the Active DNS updating on the router.
2nd The username, password and other information will be found in the documentation for the router Or online or whatever you set the login/password up to be when you set up the router
3rd. Find the area for Active DNS and input the Active DNS service information and domain name
The router will take care of the rest for you!
Step 4: Port Fowarding
Setting up port forwarding
3rd. The Raspberry Pi 2 needed to be connected to the router via Ethernet.
4th. Find the connected devices area and copy the IP address of the raspberry PI 2.
5th. Use the individual port forwarding section and use the IP address of the Raspberry Pi 2. The choices that matter are from port which in my case was from port 80 to port 80 and the Raspberry Pi 2's IP address.
6th. This should be all you need to do as long as you have a web server installed on the Raspberry Pi 2!!!!
    • Woodworking Contest
      Woodworking Contest
    • Make it Move Contest
    • Casting Contest
      Casting Contest
