3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Setting up basic x10 for newbies
Turning on and off your lights with a non-ir remote is really easier and cheaper then it looks and sounds. This how-to shows how to configure an x10 remote for 2 lights. Also shows using a label-making machine to label the remote.
Step 1What is x10, and what is this project about?
x10 is the next step towards home automation. Can you imagine opening your garage with a remote when you come home from work, and also turning on your lights wiht a different remote? Sounds like it would cost alot of money and technical understanding. But the truth is, and the x10 wiz people don't want' you to know this, it's easy to do and pretty cheap. I picked up this remote and 1 reciver for $20 at Radioshark. I got the other reciver later. they can be REALLY cheap on ebay.
10 comments
Dec 5, 2009. 3:58 PMbombmaker2 says:
o wow i hav the same exact label maker, except for the label that says PAUL'S LABEL MAKER
Mar 21, 2006. 2:24 AMgeo says:
I also have full source code for an x10 daemon program I wrote, which allows you to control your whole x10 system from a PC running Linux. Please let me know if anyone's interested, and I'll post the file in a new project
Jan 15, 2009. 4:27 PMthefutureisnow says:
I'd like to see your X 10 code.
Mar 21, 2006. 12:46 PMdriggs says:
Yes, please. It would be much appreciated...
Mar 16, 2008. 11:13 AMrethomas1972 says:
Take a look at www.x10.com. Each module shown above with the antenna can control up to 16 different functions and a 16 switch hand held remote and a 4 button key chain remote available, With the 16 numerical items there is also A to Z Alpha settings for a combined capability of 256 controllable functions using multiple Transceiver modules. You can even get a programmable TV remote with the X-10 controls on it. They also have a "Whole House" option which allows you to control things with your computer they can even control your house function by internet. X-10 also has a great line of remote cameras.
Mar 16, 2008. 10:55 AMrethomas1972 says:
Fluorescent lamps can be turned on & off by using an "APPLIANCE MODULE" instead of "LAMP MODULE" but they cannot be dimmed .
I have pulled the appliance module apart & removed the AC plug & receptacle & "Hard wired" the module into the fixture. I have also done the same thing with ceiling fans. See Geo's Instructable
http://www.instructables.com/ex/i/6A1D1BCECA231028A849001143E7E506/
Oct 4, 2006. 2:19 PMChico says:
Nice instructable! My only issue/disappointment with x10 is that it doesn't handle flourescent lightbulbs. So if the circuit you are controlling has some, plan on using incandescent bulbs instead. Otherwise, it will drive you NUTS!!!!
Oct 8, 2007. 8:18 AMAlexPDL says:
X10 Can handle fluorescents... I think there are issues with dimming fluorescents though. Just make sure it's a fluorescent compatible x10 module. I use three X10 items with fluorescents... two wall switches and a lamp plug module. Never had a prob.
Nov 12, 2006. 1:43 AMsunyi says:
Nice instruction! Isn't The first word in step 7 should be "mounting"?
Mar 21, 2006. 2:17 AMgeo says:
See also my project here, about modifying your x10 wall switches to add local dimming capability:
//Geo
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:l0cke
w00t
