Seven Segment Display Tutorial by Bot1398
Featured
How many TV shows and movies have some mysterious device counting down to zero those displays are 7 segment displays.With the 7 segment displays you can display any number or some alphabets that your heart desires.
At first controlling a 7 segment display seems quite complex but it quickly becomes clear.
What follows is a quick guide to control a 7 segment display with a arduino board
If you want to jump ahead to any other part here's your chance:
Step 1 - What Is A Seven Segment Display?
Step 2 - Parts & Tools
Step 3 - Testing
Step 4 - Built The Circuit
Step 5 - Project 1- One Digit Count Down Timer
Step 6 - Multiplexing
Step 7 - Project 2 - Two Digit Count Down Timer
This instructable is a entry in the arduino contest so if you like it please vote.
Step 1: What Is A Seven Segment Display?
A seven-segment display (SSD), or seven-segment indicator, is a form of electronic display device for displaying decimal numerals that is an alternative to the more complex dot-matrix displays. Seven-segment displays are widely used in digital clocks, electronic meters, and other electronic devices for displaying numerical information.A seven segment display, as its name indicates, is composed of seven elements. Individually on or off, they can be combined to produce simplified representations of the arabic numerals.The seven segments are arranged as a rectangle of two vertical segments on each side with one horizontal segment on the top, middle, and bottom. Additionally, the seventh segment bisects the rectangle horizontally. There are also fourteen-segment displays and sixteen-segment displays (for full alphanumerics
samalert says: Mar 20, 2012. 10:18 AM
not into electronics seriously but that 1 rupee got me here so see my brothers .... its gud instructable never have i thought tat 7 segment display is so hard .... for u it might be a piece of cake for me its like O_O
sreeraj says: Mar 25, 2012. 9:13 AM
the indian rupee is the thing that lead me here too.
mohtaprashantrocks says: Apr 8, 2013. 7:13 AM
me #3
powerman666 says: Jun 24, 2012. 7:06 AM
Ever hooked up a common anode 7 segment display?
blinkyblinky says: Aug 31, 2012. 5:38 AM
I talk about common anode and what to do about it although the process is a bit tedious...if you can only find common anode (like me) then it is worth it.
Bot1398 (author) says: Aug 30, 2012. 8:17 PM
No,but it shouldent be difficult just make all the ones to zeros and all the zeros to ones in the code and you should be ready to go.
andreicek007 says: Jul 4, 2012. 2:37 AM
What software did you use to create that circuit image? Thank you!
m1s73r says: Jul 11, 2012. 1:34 PM
It's called Fritzing...
m1s73r says: Jul 11, 2012. 11:52 AM
Unfortunately I can't test my 7-Segment Display... Your method is not working. I'm using a KINGBRIGHT SA52-11GWA.
I think its a common anode one...
Could you please add a detailed tut on testing these?
Thanks
Applebohn says: Mar 30, 2012. 9:17 AM
way to copy from wikipedia
rammstein2 says: Mar 25, 2012. 10:33 AM
FYI a single 7-segment display can display 126 symbols. ;-)
jeffconnelly says: Mar 27, 2012. 2:23 PM
Wikipedia says 128, actually. Although "symbol" doesn't mean actual LETTER...
estope says: Mar 29, 2012. 2:04 PM
no need for wikipedia, simple math: 2^7= 128
akowalczyk says: Mar 29, 2012. 3:14 PM
Actually, 255 - there is a decimal point - and I don't count all blank as a symbol YMMV
estope says: Mar 29, 2012. 8:20 PM
well, de decimal point makes it an eight-segment display i guess. and all blank is a symbol, you can asign a meaning to it as to any other combination. but i think we are leaving math behind and getting too phylosophical...
mr monoply33 says: Mar 29, 2012. 4:37 PM
Oi, I wish this was out about six or seven years. Spent hours if not days just going trial and error trying to figure out how to wire up some of these I mail-ordered. No good online tutorials at the time. I started to have trouble when I wired more than 5 displays together. Random segments would go out. Maybe the current got too low by that point... The lesson I learned from messing with them is, hot-glue is very hard to get off the back, and out of these displays.
dumle29 says: Mar 25, 2012. 9:24 AM
As these pictures show, you have chosen wrong resistors. When working with leds with 1 common pin, you should attach a resistor for each individual pin for the LEDs. This is because the more leds you turn on, the more ma the display would require. I know its a pain, but its the correct way.
qwerty156 says: Mar 20, 2012. 3:58 AM
Good Instructables for beginners
Its nice to see someone else my age interested in electronics, even better if they are from india :D
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
