3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Several Easy Steps to Boost Your Computer's Speed
Step 12Remove Startup Tasks & Decrease Boot Time (System Configuration)
In Windows Vista, all of Windows' essential programs are loaded through something called "Windows Services." This means that most of the startup items you see in Vista are completely optional and can be turned off. However, a good rule of thumb is to disable only those programs that you recognize and don't need to have running all the time. When in doubt, leave it on. Or, better still, check out Paul "PacMan" Collins' huge "Startup Applications" list at http://www.sysinfo.org/startuplist.php . This list of over 13,000 startup items you may encounter in MSCONFIG tells you which items are absolutely necessary, which items are optional, and which items you should definitely uncheck.
Here is where you can find it:
Start Menu
Select "Run" on the right hand side
In Dialog Box, type in: msconfig
Click OK
In dialog box, go to the "Startup" tab
Uncheck the programs you don't want to run at start up.
If you have a multiple core CPU (Ex: Intel Core Duo or Quad CPU) or multiple CPUs, then this will show you how to change the Number of Processors that will be used during boot up.
In dialog box, go to the "Boot" tab
Click on the Advanced options button.
Check the Number of processors box, then click on the drop down arrow and select the number of available processors (cores or CPUs) you want to have used at boot up.
Click on OK.
Click Apply
Click on OK.
You will then be prompted to restart your computer.
8 comments
May 10, 2011. 10:52 PMlondobali says:
Nice job!
will help a lot specially for my old laptop here.. :)
owh, this link is not working: http://www.sysinfo.org/startuplist.php.
there's a point in the end of the link.. it should be http://www.sysinfo.org/startuplist.php
cheers..
Mar 13, 2011. 7:01 AMcscott-4 says:
I never knew about this! Thanks a ton - it really helped me out. :3
Mar 2, 2010. 2:15 AMpeukman says:
A nice freeware to manage these programs at startup is StartupCPL.
You can get it here
Jun 12, 2010. 8:55 AMJohndmcc says:
I just wanted to let you know. Your link for the system check, you have a period at the end of it that's messing with the link. If you click on it alone, you will come up with a 404 File error. I would suggest either, taking out the period, or for everyone to just copy and paste.
Jun 14, 2010. 12:29 PMJohndmcc says:
Just thought I would try and be helpful. I have done just about everything on here. It works wonders for the most part. Right now, I have a Dell Latitude P.O.S. and it is slower than frozen molasses flowing up hill in Jan. But, it's a lot faster now !!!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
75
Author:lukethebook333
Welcome! Please take some time to take a look at the instructables that I have made. Computer slow? Want to learn how to use Craigslist? Tired of knocking the water out of your ears after swimming? Wa...
more »
