Step 2Reboot your Computer
This memory is utilized to store information while computer is powered on. Once power is switched off, information from the memory gets erased automatically, because it requires a constant electrical charge to maintain its contents. RAM then is ready to be available once computer is powered on again. Hence it is named volatile memory. It is written and accessed randomly, which is why it’s called RAM.
With that over with, the basic idea to this step is to not have your computer on for a long period of time.
If you want to reset all the bits in your RAM, turn off your computer, and leave it off for about 5 minutes. Then reboot the computer, and your RAM should be wiped clean!
* If you are going to be using the computer in an hour or two, just put it into hibernate or sleep mode.
* If you are leaving it for over 10 hours, you probably want to shut it down.
* If you have your computer on and you’re using it for over 10 hours, do something else! At least shut it down and turn it back on if you notice it becoming sloth-like.
RAM needs to be unpowered (computer being off) for 5 minutes (give or take) for the data to be removed
1) not because the RAM fills up (though I can't remember what the real reason is) and
2)mainly something that happens on Windows PCs. Those of us using GNU/Linux or Macs can get quite literally years of uptime with no slowdown, though most people have to reboot every now and again for kernel updates and such.
About the second comment: I do realise that this instructable appears to be aimed at Windows users. Not a problem with me - I use it sometimes as well, you know. Just using the others here as examples to demonstrate that the reboot thing isn't universal.
*ahem* yabber over, you can stop ignoring me now.
