3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Several Easy Steps to Boost Your Computer's Speed
Step 30If all else fails....
  • last photo ←
Unfortunately, sometimes you cannot speed your computer by just doing this alone. If these steps weren't enough, then it's time to upgrade your components of your computer.
This includes:
* Memory.
* CPUs / Processors.
* Hard Drives.
* Video Cards & Devices.
* Fans & Heatsinks.
* Power Protection.
* Operating System.
* New Computer.
* Memory.
The cheapest way to boost your computer's performance. Also known as RAM. This is a great tool for boosting your computer's speed. Although Memory is specific to each computer, so be sure to use this system scan to determine the type and maximum amount of ram for your computer.
Scan my system for the right type of RAM
Random-access memory (usually known by its acronym, RAM) is a form of computer data storage. Today it takes the form of integrated circuits that allows the stored data to be accessed in any order (i.e., at random). The word random thus refers to the fact that any piece of data can be returned in a constant time, regardless of its physical location and whether or not it is related to the previous piece of data.
The next step up, is to upgrade your CPU. The CPU is often considered the heart of the computer. It runs the show whenever your computer is on. This is a little more costly, but will be a major asset to your computer in the long run.
CPU makers have struggled in recent years to keep upping the productivity of CPUs without adversely affecting either their power requirements or heat output. Put simply, the more power a CPU uses, the more heat it's likely to produce, which makes it costlier to run -- and requires ever larger power supplies -- as well as having a limiting effect on the lifespan of the processor itself, as greater heat will burn out a processor much more quickly.
Both AMD and Intel are combating the problem with multi-core CPUs. These are CPUs that contain not one, but two, three and four core processors, with dedicated cache memory for each processor. Dual-core CPUs were the first to hit the market with AMD's Athlon 64 X2 range of chips, and Intel's Pentium Processor Extreme Edition 840. Currently, the Core 2 Duo is Intel's most popular dual-core CPU, while AMD's X2 range is still going strong. Sticking two processors into a PC isn't entirely new, although it's largely been the domain of more enterprise-based computing to date. However, if you're running software that can take advantage of multiple processors, you should see improved performance with a dual-core CPU.
Likewise, if you're a fan of running several heavy-duty processor applications simultaneously -- say, running a virus scan while simultaneously encoding video and perhaps doing some light Web surfing -- you should see benefits from a dual-core approach. And quad-core CPUs offer even more scope for multitasking.
Intel's Core 2 Extreme QX6700 was the first quad-core CPU to hit the market, and it's essentially two Core 2 Duo E6700 CPUs in one package. AMD's Phenom CPUs contain four individual cores, rather than consisting of two dual-core parts, and AMD refers to this as a 'native' quad-core design. The use of individual cores has also allowed AMD to announce a CPU with three cores in it -- a tri-core CPU -- which may be a viable solution for users who want more power than what a dual-core CPU can offer, but who can't afford a high-end quad-core CPU.
If you think quad-core isn't enough for your needs, consider a dual-CPU socket system from AMD that can run two quad-core CPUs, for a total of eight cores! The octa-core platform, which requires a special motherboard with two Socket F sockets, can run two quad-core AMD Phenom FX CPUs.
CPU stands for Central Processing Unit, and even after many years of refinements in PC technology, the CPU is still the core of your computer's operations. It controls the flow of data throughout your entire PC (hence the central part). The processing part is equally vital, as the role of the CPU is to manipulate -- or process -- the data that passes through your computer, reading it from storage devices, changing it as required, and then writing it out to storage or display devices.
* Hard Drives.
Your PC's internal hard drive is a real workhorse--the most critical component of your system after the CPU and memory. The hard drive is the hub where your operating system, programs, and data are permanently stored and accessed.
If you edit movies, take lots of digital photos, play games, or listen to music files on your PC, a big, fast internal Parallel or Serial ATA hard drive can dramatically improve your overall computing experience. If you need more storage or a means to back up your PC's internal drives, you can add an external hard drive--available in USB 2.0, FireWire 400 or 800, or external SATA flavors. And if you want centralized storage, consider buying a network-attached storage device. NAS devices are continually improving, and can be a convenient way to add storage that all of the PCs on your small or home network can share.
A video card, also known as a graphics accelerator card, display adapter, or graphics card, is an expansion card whose function is to generate and output images to a display. Some video cards offer added functions, such as video capture, TV tuner adapter, MPEG-2 and MPEG-4 decoding, FireWire, light pen, TV output, or the ability to connect multiple monitors. Update your Video Card, and you'll see a much cleaner screen and you may have a faster computer for videos etc.
A common misconception regarding video cards is that they are strictly used for video games. Video cards instead have a much broader range of capability, for example, they play a very important role for graphic designers and 3D animators, who tend to require optimum displays for their work as well as faster rendering in order to efficiently tone up their work.
* Fans & Heatsinks.
Heat sinks are widely used in electronics, and have become almost essential to modern central processing units. In common use, it is a metal object brought into contact with an electronic component's hot surface  though in most cases, a thin thermal interface material mediates between the two surfaces. Microprocessors and power handling semiconductors are examples of electronics that need a heat sink to reduce their temperature through increased thermal mass and heat dissipation (primarily by conduction and convection and to a lesser extent by radiation). Heat sinks have become almost essential to modern integrated circuits like microprocessors, DSPs, GPUs, and more.
A heat sink usually consists of a metal structure with one or more flat surfaces to ensure good thermal contact with the components to be cooled, and an array of comb or fin like protrusions to increase the surface contact with the air, and thus the rate of heat dissipation.
A heat sink is sometimes used in conjunction with a fan to increase the rate of airflow over the heat sink. This maintains a larger temperature gradient by replacing warmed air faster than convection would. This is known as a forced air system.
* Power Protection.
Two words: Surge protector. Get one to keep your computer safe during power outages AND surges.
* Operating System.
Often times if push comes to shove, an updated version of your Operating System can help a lot. In order to do this, though, make sure your hardware can accommodate the change!
* New Computer.
Sometimes you just have to say goodbye and bury it. *tear*
3 comments
Jul 17, 2010. 8:01 PMshortw says:
Upgrading hardware may help a little bit, but formatting and re-installing windows is way more effective if you have a windows program. Caution if you format, you will loose all your programs and there is no way to reverse it. Check and read how to install the windows-program first before doing so.
Mar 30, 2009. 3:48 AM77bruce says:
Upgrade always seems to be the last resort
Mar 22, 2009. 12:34 PMlordyoyo says:
You've underestimated your guide. If somebody does the things you've recommended, and they haven't been done on his system, it will definately speed his pc up. Kudos ;)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
75
Author:lukethebook333
Welcome! Please take some time to take a look at the instructables that I have made. Computer slow? Want to learn how to use Craigslist? Tired of knocking the water out of your ears after swimming? Wa...
more »
