3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Several Easy Steps to Secure Your Computer
Step 4Wireless Network
Wireless Network
Use a router to share an Internet connection
Consider using a router (also called a residential gateway device) to share an Internet connection. These devices usually have built-in firewalls and other features that can help keep your network better protected against hackers.
Don't stay logged on as an administrator
When you are using programs that require Internet access, such as a web browser or an e-mail program, we recommend that you log on as a standard user rather than an administrator. That's because many viruses and worms can't be stored and run on your computer unless you're logged on as an administrator. Another point is to not stay logged on period whenever you are away from your computer for any length of time.
Use a network security key
If you have a wireless network, you should set up a network security key, which turns on encryption. With encryption, people can't connect to your network without the security key. Also, any information that is sent across your network is encrypted so that only computers that have the key to decrypt the information can read it. This can help avert attempts to access your network and files without your permission. Common wireless network encryption methods are Wi-Fi Protected Access (WPA) and WPA2.
Change the default administrator name and password on your router or access point
If you have a router or access point, you probably used a default name and password to set up the equipment. Most manufacturers use the same default name and password for all of their equipment, which someone could use to access your router or access point without you knowing it. To avoid that risk, change the default administrator user name and password for your router. Check the information that came with your device for instructions about how to change the name and password.
Change the default SSID
Routers and access points use a wireless network name known as a service set identifier (SSID). Most manufacturers use the same SSID for all of their routers and access points. We recommend that you change the default SSID to keep your wireless network from overlapping with other wireless networks that might be using the default SSID. It makes it easier for you to identify which wireless network is yours, if there is more than one nearby, because the SSID is typically shown in the list of available networks. Check the information that came with your device for instructions about how to change the default SSID.
Position your router or access point carefully
Wireless signals can transmit a few hundred feet, so the signal from your network could be broadcast outside of your home. You can help limit the area that your wireless signal reaches by positioning your router or access point close to the center of your home rather than near an outside wall or window.
For more information: http://windowshelp.microsoft.com/windows/en-US/help/bf6372bb-c95c-4b39-aa50-de7e5bf034681033.mspx
1 comment
Aug 18, 2011. 5:36 PMgorth says:
There are programs that will break 128bit network security keys. Keep a look out on your network and if u see computers that yoou do not know then set up MAC Address filtering to only allow the computers you know to access your network. I had a neighbor that would bug on to my wireless network to do his uploading. i set up WEP keys and it took him less than an hour to get the key, log on and start uploading again. I set up MAC Address filtering and it's been 2 weeks an he hasn't been able to get on.
Nov 4, 2011. 2:29 AMneumanngregor says:
MAC filtering can b bypased too, it takes to see you connected and then he disconnects you and spuff ur MAC and start the dictionary/rainbow table attack again, if u wanna keep som1 out u need a SSID randmoly generated that has a maxlenght of 32 characters and your PSK key from WEP2 (only) of 63 characters long, both shud be random letters and numbers.
Example :
SSID: SEuB2ScDk9VMPhEuoBXTp8bdSinLnPZs
PSK : nWIz0u45bccqyI9aXsu464jKVAm6LTXSGwnZl8adEjGF7v7eHeQawyL1ELx3Y8z
This will make all dicitonsry and rainbowtables useless. WEP2 use the SSID to 'salt' the key, and thats why u need to change it to somthig new and unique.
For paranoid ppl they cann add a internal VPN for more security :D.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
75
Author:lukethebook333
Welcome! Please take some time to take a look at the instructables that I have made. Computer slow? Want to learn how to use Craigslist? Tired of knocking the water out of your ears after swimming? Wa...
more »
