Step 5Remove Background Programs (Task Manager)
How to start Task Manager
To start Task Manager, take any of the following actions:
- Press CTRL+ALT+DELETE, and then click Task Manager.
- Press CTRL+SHIFT+ESC.
- Right-click an empty area of the taskbar, and then click Task Manager.
Features and uses of Task Manager:
- View Programs that are running
- View Processes that are running
- Performance measures
The Applications tab displays the status of the programs that are running on the computer. To exit, switch to, or start a program, follow these steps:
1. Click the Applications tab.
2. Do one of the following, as appropriate for the action that you want to perform:
- Exit a program
Note When you exit a program in this manner, any unsaved data in that program is lost.
- Switch to another program
- Start a program
Note This procedure is very similar to starting a program by using the Run command on the Start menu.
How to end a process
The Processes tab displays information about the processes that are running on the computer. A process can be an application that you start or subsystems and services that are managed by the operating system. To end a process, follow these steps.
Note Proceed with caution when you end a process. If you exit a program in this manner, data that has not been saved will be lost. If you end a system process, a system component may no longer function correctly. To match a process with a running program, right-click the program name on the Applications tab of Windows Task Manager, and then click Go To Process.
1. Click the Processes tab.
2. Do one of the following, depending on the action that you want to perform:
- If you want to end a single process, click the process that you want to end, and then click End Process.
- If you want to end a process and all processes directly or indirectly related to it, right-click the process that you want to end, and then click End Process Tree.
Click the Performance tab to view a dynamic overview of the performance of your computer. This includes the following measures:
- Graphs for CPU and memory usage
- The total number of handles, threads, and processes that are running
- The total number of kilobytes (KB) that are used for physical, kernel, and commit memory
Add Comment
