3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Sew Useful Contest: Make Your Own Buttons
This past Christmas, my parents moved away from my childhood home on the coast of New England. My mother gave me a collection of sea glass and shells as a gift so that I would have something to remember the ocean.
Right after the holidays, I popped a button off of my peacoat and lost it. I didn't want to repair the coat with a mismatched button, so I decided to make some sea glass buttons instead.
I found sea glass hard to photograph against the white background, so I am using red fused glass cabochons for this instructable. The directions for sea glass are exactly the same.
I created this instructable for the Sew Useful Contest. You can find the accompanying Etsy listing here.
Step 1You will need...
You will need...
Materials and Tools
  • Glass cabochons (if you don't have access to sea glass or shells you can buy artisan cabochons)
  • Drill with Flex-Shaft attachment and 1/16" and 1/32" collets (available at Lowe's, Home Depot, etc)
  • Carabineer Clip
  • Crystalite Triple Ripple diamond drill bits, .75 - 2.1 mm (made by Abrasive Technology, Inc.)
  • Shallow plastic bowl
  • Water
  • Safety goggles
  • Ear plugs (if you have sensitive ears)
14 comments
Aug 6, 2011. 7:22 AMtriumphman says:
Do you have a picture of an actual sea shell being drilled or one you finished drilling ?
Feb 26, 2010. 12:11 PMthepelton says:
I have been working at goodwill sorting clothing, and recently I saw a garment with buttons made of cowrie shells (Cypreaea Moneta).  The button maker drilled holes in the back running through the shell's mouth.
Jun 12, 2007. 4:26 PMMomma says:
I have some very old buttons. Buttons were originally made out of mother of pearl. It's a great idea.
May 24, 2007. 3:00 PMSupernovaDesigns says:
How can you be sure that when you flip the button over, you are drilling over the hole on the front side?
May 23, 2007. 6:56 PMKnittingFreak says:
Wow!! Those are beautiful. Is there a way to make buttons from oyster shells?
May 24, 2007. 4:39 AMironsmiter says:
Sure there is a way :-) goto the beach, and get a LOAD of shells. use a pair of wire cutters to rough cut the button shape from a flatish portion of the shell. drill the holes using the slowest speed possible, and with NO pressure. let the bit's weight do the work or you'll crack the shell. then finish off with sandpaper, file or emery board. Also works using coconut shell, wood, plastic... just about anything your heart desires
Feb 26, 2010. 12:13 PMthepelton says:
Limpets would not have to be precut.  For other shells, I would probably use a plug cutter in a power drill.
Jan 11, 2008. 2:17 PMprincessbunnyrooroo says:
Best to use diamond bits (cheap at harbor freight) with rotary tool like dremel - do it under water to prevent diamond clog & inhaling the poison dust. Oil (baby oil) works well too. You can get a variety of tip shapes that will work on thicker or thinner, harder or softer shell. On the other hand you can buy metal "button shanks" at bead stores to epoxy on to whatever you want to have a button of --but it doesn't look too good with transparent bobbles like the glass. Oh also they sell "wet sandpaper" in super high grits for automotive finishes (up to 1200 I have), that will give you the final gleam that hardware stores 300 grit can't. Plus the water drowns that nasty dust. The paper is a bit more expensive, but way more long lived - it's the only type I use now.
May 25, 2007. 1:03 PMdataphool says:
Very good job! to you and liskidder. I was just about to ask the same question as KnittingFreak. [making buttons from oyster shells]
There are no oysters around here, but there are lots of clams about 300 yards away, and local fishermen come ashore with scallop shells only a little further away.
May 25, 2007. 1:05 PMdottyral says:
Great job Lis!
May 24, 2007. 1:57 PMcanida says:
Gorgeous! I'll have to give it a try. As for photographing seaglass, try it against a black velvet background.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:liskidder
