Introduction: Sew a Unique Coffee Bag Apron
The folks over at Donkee House have some amazing, authentic coffee bags that can be the starting point for many creative projects including totes and pillows. The design is unisex and would be a perfect gift for the coffee lover in your life. What a unique and purely organic apron this is!
Step 1: Supplies
- one coffee bag, washed, dried and ironed.
- 1 1/4 yards fabric for lining, washed and dried
- ruler
Step 2: Cut Lining Fabric to Make Straps
Begin by making three strips of fabric. Two of these will become the waist ties and the third will be the next strap. Lay out lining fabric with selvage edge folded together. Cut three strips, each 4" wide. Shorten one of those strips to 24" (this will be for the neck strap.)
Step 3: Press Straps
To finish the edge on the two long straps fold in 1/4" on one short end and press. (The other end will be on the inside of the apron.)
Fold strips in half with long edges together and press.
Open out strip and fold one long edge to meet the middle and press. Repeat with the other edge so that both raw edges are now folded and meeting at the middle.
Fold in half again so raw edges are completely enclosed and press.
Step 4: Top Stitch Straps
Top stitch close to folded edge.
Step 5: Cut Bag
Cut bag along edges.
Step 6: Find the Design Center Point and Cut Bag
Mark the center point of the motif. Even out the sides and bottom of bag. In this example, there was 5.25" to the right of the motif. So I cut off the excess on the left side for an overall size of 23.5" x 35".
Step 7: Cut Out Arm
Mark 5.5" to the left and right of the center point; mark 11.5" down on the sides.
Draw a curve between the two points and cut out that top portion of the apron. (You could also trace an existing apron.)
Use the cut out piece as a pattern to make the same cut on the other side.
Step 8: Cut Lining
Place lining fabric underneath the bag and cut out.
Step 9: Pin Straps
Pin ties to right side of lining, raw edges together. The shorter strip is the neck piece and the longer strips are the waist ties. The ties should be placed one inch from the sides edges.
Place right sides together and pin so that the straps are encased on the inside.
Step 10: Sew
Sew or serge using a small stitch length and a 1/2" seam allowance around the perimeter of the apron. Leave a 6" opening at the bottom. Trim curves and corners being careful not to trim too closely since the weave of the burlap is somewhat loose. Turn apron inside out and press; press the seams of the opening to the inside and pin.
Top stitch the entire apron using a fairly small stitch to secure the coffee bag to the lining and reinforce the weave of the burlap.
