loading
Are you guys excited for the movie? I'm geeking out over here. I'm totally wearing this opening night.
This is a really simple pattern - the whole hat is only eight pieces!
LET THE WILD RUMPUS START!
The pattern is on STEP 2 - scroll down to the bottom of the step and click on the PDF there! If you can't get it that way, I've uploaded it docs.google.com/fileview. :D
p.s. - Please ask if you have any questions!
p.p.s - Someone on craftster made their own version with fuzzy fabric!
http://www.craftster.org/forum/index.php?topic=319985.20
Just scroll down a bit and you should see it!
Step 1: What you'll need...
  • white polar fleece - 1/2 yd, just in case!
  • 24 gauge black plastic coated wire or long black twist-ties for the whiskers
  • 24 gauge white plastic coated wire to keep the ears upright
  • scissors
  • white thread and a needle and/or a sewing machine
  • the pattern, which is attached as a PDF on the next step!
If you're worried about using wire in the hat, Kiteman has this suggestion:
Soak the string in slightly-diluted PVA glue and leave it to dry (If you dry it draped over a pile of scrap plastic bags, it will set in a twiddly shape).
Step 2: Pattern information.
This pattern is tailored to my head size, which is:
21 1/2 inches around, measured right above the ears,
and 13 1/2 inches from center line of head to shoulder.
...but you can easily alter it to fit you if you have a larger/smaller head. I'll go over this in the next two steps. :)
The pattern will print out on five pages. Four of the pages will be the hat, one will be the ear pattern and the test square! The test square should be 4x4 inches when the pattern is printed correctly!
I apologize for the wonky, terrible scans. Both scanners were givin' me lip. I couldn't get them to do anything properly. Some lines will be a little crooked, but that's okay!
To download the pattern, click the Adobe icon below!
Step 3: Assemble the hat pattern!
The four hat pieces will need to be overlapped and taped together. They have little diamonds so you know when they're lined up!
To assemble the hat pattern, do the following:
  • leave the top left piece whole
  • cut off the left edge of the upper right piece
  • cut off the top edge of the lower right piece
  • cut off both the top and right edge of the lower left piece
Then tape together, following the pictures, so the edges are overlapping!
Step 4: Making the pattern larger.
*Seam allowances are included, so don't worry about those!*
Measure your head around right above the ears and from middle scalp to shoulder. Once you have these measurements, figure out the difference for each compared to mine.
If you only need to increase CIRCUMFERENCE, FOLLOW THE PURPLE LINE:
add to the front of the hat, as shown below. Simply take a ruler, measure how ever many inches from the front line, and draw. Increase the size of the bottom flap as well. :)
If you need to increase CIRCUMFERENCE and LENGTH, FOLLOW THE GREEN LINE:
add to the back part as shown below. Measure up from the top left corner, and continue adding how ever many inches all the way around.
If you need to increase LENGTH, FOLLOW THE ORANGE LINE:
add to the bottom of the hat only, increase the size of the front flap as well. :)
Easy peasy. :)
Step 5: Making the pattern smaller.
This is much easier. Simply draw a smaller line inside the pattern line. If you're smaller in one particular area, use the same techniques but draw inside the pattern line.
The gigantic blue scribble shows you where to go!
If you're going more than an inch smaller, I would decrease the size of the front flap as well, by at least a 1/2 inch. :)
Step 6: Cut out your pattern pieces!
Make sure you're nice and careful during this. You don't want a wonky pattern! :D
Step 7: Cut out four of each piece - hats and ears!
Cut out the hat pieces first, and then the ears. The hat pieces take up more room and have to be placed in certain ways.
The trick with the hat pieces is two get two sets of them - and when the curved backs are facing eachother, they both need to have the right side (the nubbier, fuzzier side of the fabric) of the fabric facing up!
Lay your piece of fabric nubby (right) side up, and then fold over the end piece so that you can fit the hat pattern on it, with the flap facing to the right. Pin it together, and cut through both layers of fabric! Do this twise. :)
The ears can be cut from any large scraps or the leftover fabric!
Step 8: Sew the hat pieces into pairs!
Place the pieces right side together (the nubby side of the fabric, remember!) and pin around the back curve.
Use the right edge of your presser foot as the seam allowance, and sew all around the curve, backstitching at the beginning and end of the seam.
Once you're done sewing both, take those scissors and trim the seam allowances. This'll make it turn out a lot smoother in the end. Don't get too close to the stitches, though! About an 1/8 of an inch away is just fine!
Step 9: Sew the ears into pairs!
Remember to do this right sides facing. :)
Use the side of the presser foot again. It makes the whole thing easier!
You can either to this by sewing two straight lines, or by sewing to about a 1/4 inch away from the tip, leaving the needle in the fabric, raising the presser foot, turning the fabric, and lowering the presser foot again and continuing to sew.
Once you're done, clip the seam allowances and especially the tips of the ears. :)
Step 10: Stuff and wire the ears.
First, turn the ears right side out, getting the seams as smooth as possible. (Use something skinny and smooth to help turn the ears! I use an old crochet hook.)
Then, take the white wire and lay it over the top of the ear, leaving an inch tail at both sides, and bend it sharply so that it will fit snugly inside the ear.
Then, insert it into the ear, trying to align the wires with the seams as best you can.
Then you'll stuff it while holding the wires in place. Stuff it pretty firmly, but not so much that it starts to look round. Leave the bottom a little less stuffed so you can sew it.
Once both ears are wired and stuffed, sew across the botttoms as close to the edge as you can, and over the wires. Don't worry about backstitching. :)
Step 11: Insert the whiskers!
Choose one of your two hat halves, and set this aside. This is going to be the outside part of the hat!
Cut 8 six inch lengths of the black wire. You can shorten them later if you want!
Swirl one end of each of these, so you have a couple loops. Take a small crochet hook or the metal end piece of a mechanical pencil, and poke four holes about a 1/2 inch apart near the front of the hat on each side. (You might want to try the hat on to get an idea of where you want them to be. Enter hat hair, as demonstrated below.)
Push the wire through from the wrong side of the hat, so that the swirly bit is on the inside. :)
Now, take a needle and some white thread, and secure these loops to the inside of the hat so they lay flat. This will make your whiskers stay in place and be more rigid! Hooray!
Once you've secured all of them, fold them up so that you can sew the whole hat together!
This step has a ton of pictures. I got excited. Sorry. :)
Step 12: Sew the two hat pairs together.
Take the piece with the wires in it, and lay it down so the right sides are out and you can see the folded-up whiskers!
Take the other piece of the hat, and turn it wrong side out. Place the right side out piece into the wrong side out piece and line up the middle seams.
Pin all around the edges of the hat, making sure to designate a place 5-6 inches long at the very bottom back to turn it right side out. Start sewing right below that place and go all the way around.
On the corners, make sure you're leaving the needle in the fabric 1/4 inch away, raising the presser foot, turning, and lowering it again. (Look below for step by step pictures)
Step 13: Trim the seams, turn hat right side out, check out your whiskers.
Make sure to clip the flap corners! Go for 1/8 inch, everywhere except the hole where you're going to turn it.
Turn it right side out, using your pokey thing to get it all turned out correctly!
You're almost a wild thing!
Step 14: Top stitch around all the edges of the hat.
Make sure your stitch length is set to the longest setting to be able to go through so many layers!
Do a straight line across the bottom first, very close to the edge. Make sure the turning hole's edges are nice and tucked in. Sew right over this to close it up.
The continue around the rest of the hat, using the stop, lift, turn, lower, sew method shown eariler. :)
Step 15: Insert the ears!
Either use the placement I've given, or choose your own by putting the hat on the moving the ears around until you like where they are.
If you choose my ear placement, simply fold and cut away the space where the line is on the pattern, and lay that over the finished hat and mark on both sides. Try to use an air erasable or water soluble marking pen, or mark on the inside of the hat.
Once you have the lines marked (they should match the width of your ears) fold the hat so that you can snip on the line and get through both layers of fabric.
Once you have a clean hole in the hat, insert the ears bottom first from the right side of the fabric, and hand sew them in between all the layers on the inside of the hat.
Push any extra wire back inside the ears.
Step 16: Turn the hat right side out and admire your ears.
I would now recommend having a wild rumpus. If this is not available, make sure to tell everyone around you "I'LL EAT YOU UP!"
Enjoy! :D
I&nbsp;just finished this for my sons 15 birthday. Sweet huh? <br />
<p>Should have posted a happier photo. Great finished btw </p>
I gotta say, he doesn't look too happy...
&nbsp;hmmm. &nbsp;is he embarrassed? &nbsp;
lol reminds me of a christmas story and the big pink bunny suit lol<br />
That's so dang funny!<br />
&nbsp;by doing this you have made a very powerful enemy...
I like it! The big ears are awesome! <br />
This hat is too cute!&nbsp; Thank you for making your instructions and pattern so easy to follow.&nbsp; It only took me a couple of hours to make a fantastic edition to my Halloween costume :)<br /> <br />
This project has won today&#39;s &quot;I Made It&quot; Challenge, for that you get a 3 month pro membership<br /> <br /> Thanks for using instructables!<br /> <br /> https://www.instructables.com/community/June-is-I-Made-It-Challenge-Month-Win-a-Pro-Me<br />
I love it! It looks so cute on you! :D<br />
omggg i had so much fun making this today! I plan on wearing it to school for our senior dress up day! LET THE WILD RUMPUS BEGIN. Oh yea! I need to make a crown for this too :] I will post another pic when thats done haha. THANKS AGAIN! :D<br />
Welcome! I'd love to see the crown when you're done! :)<br />
hah, kinda late but yea..here was the crownn :D<br /> <br />
&nbsp;Hey thanks for the help! this made some great hats for me and mahfriends!!! i hope u do well!!&nbsp;<br /><br />i dont know how to sew so i used hot glue, and iron on mending tape.. :(but they came out very well<br /><br />if u wanna see the pics<br /><br />
Might I suggest, profile pic? <div id="refHTML">&nbsp;</div>
This picture is freaking hilarious. Seriously. :P<br />
Thanks, this was very helpful, especially when it came to the ears. I used silver twisty ties for the whiskers since I&nbsp;knew they couldn't poke my two year old and they went in great, though better the first time than the second. (I initially placed them too high.) Anyway, Micah loves his &quot;Max Monster&quot; hat.:-)<br />
Thank you for your awesome pattern, I was able to make full costumes for halloween &amp;&nbsp;they turned out AWESOME&nbsp;:D<br /> <br />
Thank you so much for the pattern!&nbsp; My son LOVES it!&nbsp; Halloween was a hit. Thank you :)
&nbsp;Helpful pictures! I couldnt figure out how to print the templates so i did my best and drew my own with yours as a reference, and i super glued the whole thing together and filled the ears with teddy bear stuffing. I cant sew for anything and have got really good at superglueing from making another costume!&nbsp;I also used pink because i was making it &nbsp;for my girlfriend for halloween and we could only get a pink adult onesy offline for a max crown halloween outfit. The colors matched up nicely.<br /> <br /> I used Seamsters instructable for the wild thing character carol! The finished products were great and it made for a fun night of halloween partying!! My only complaint was that when i was connecting carols bottom jaw to the top part of his head, i cut my finger wide open with scissors! Now his cotton filled head looks like real brains with all the blood that spilled inside! Luckily noone can see that part<br /> <br /> Thanks for the pictures and directions :0)<br />
thanks so much for&nbsp; your tutorial! i used it to make my two year old's halloween costume. it was so much fun!<br />
<strong>&nbsp;Let the wild rumpus start!<br /> <br /> Thanks for the pattern - I had lots of fun putting it all together!<br /> <br /> </strong>~Adam &quot;Sunny&quot; Flanders<br /> http://www.adamflanders.com<br /> <strong><br /> &lt;3<br /> </strong>
Yeah. Oh yeah. The movie was great. It made me want to <a href="https://www.instructables.com/id/Quinzee-Building/">build a snow cave</a>! Oh, and:<br />
I&nbsp;know I already said it, but the cuteness is overwhelming. :P<br />
Every day! :-D<br />
&nbsp;i sewed this from your pattern!<br /> &quot;woman, FEED ME! or i'll eat you up!&quot;
Hahaha, the look on your face totally suits the quote! :D<br />
&nbsp;hahah thank you! that's what i was aiming for :]
after completing the hat, i took a stab at the rest of the costume too.<br /> <br /> these are some action shots from my office halloween party yesterday. since the party was a week early, we got some weird looks when our wild rumpus took to the streets. i responded by roaring and stomping my feet and threatening to eat people up.<br /> <br /> sorry there isnt a better close-up of the hat. your instructions were great so that part definitely turned out the best.<br /> <br />
I love the second picture! You could totally photoshop yourself into the book and it would work! Great job! :D<br />
i lined mine in silver silk and used the wire from a spiral bound notebook. its perfect for a wild ROMPUS!
Yessss! I love that everyone is making the face. :D<br />
Please ignore the weird look on my face.... :)<br />
Oh, I like that fabric, what a good choice! :D<br />
Oh yeah.&nbsp; My husband had the idea of putting flexible wire in the ears so I could move them around.&nbsp; It worked out really well.<br />
&nbsp;I made a crown too :) thank you so much for this tutorial! <br /> LET THE WILD RUMPUS START! &lt;3
That is a fancy crown!!!<br />
Loved making this! My pre-K class will love it!
I really really like the whiskers on yours! :D<br />
&nbsp;Thank you thank you thank you for this! I (well, more my mom, my sewing skills are not quite up to par... I did do everything else though :D )<br /> I ended up going to a Halloween party and I won third place with this! (Well, that, and my crown and scepter probably helped too, but everyone LOVED the hat)<br /> Thank you again!<br /> (I didn't get a chance to color my whiskers before, so I plan on doing that before Halloween...)
Yayayayayay! It's totally cute! You look so happy! :D<br />
I took your design and upped it a level! I added headphones!<br /> Also I used fake fur instead of fleece and I moved the ears to be more like they are in the book.<br /> (the movie was awesome by the way)<br />
&nbsp;hey were do u guys get the whikers PLEASE answer to me thxx
I&nbsp;found my wire at Michaels... near the jewelry section. It wasn't plastic covered... and I&nbsp;think it was around 20 guage :)
&nbsp;liek wat kindd of wire
i used pipe cleaners. i couldn't find anything else. they work well :)<br />
Just regular, stiff wire. You might try radio shack and ask them, but since I did mine at the last minute, I didn't add whiskers (I didn't have any stiff black wire on hand).<br />
&nbsp;liek wat kind of wiree
About This Instructable
266,734views
925favorites
License:
Bio: part of the Instructables Design Studio by day, stitch witch by night. follow me on instagram @makingjiggy to see what i'm working on! ^_^
More by jessyratfink:how to adjust to high altitudes  Embroidered Flowers With French Knot Centers no chill sugar cookie recipe
Add instructable to:
