To make one visor, you will need:
Paper for tracing out patterns
1/2 yard fabric -- I used cotton but fabrics with similar properties should work as well
1/2 yard heavy fusible interfacing*
1/2" elastic (about 7")
Thread
Scissors
*The interfacing I purchased was Pellon 931TD, labeled as "medium to heavyweight" which isn't particularly thick or inflexible. If your interfacing is quite stiff and thick, it's too heavy for these instructions as I've written them.
Remove these ads by
Signing UpStep 1The Brim Pattern
1. Draw a half circle with a 3 3/4" radius using the bottom of the line as the center.
2. Measure up 4.5 from the bottom point and draw a half circle with a 4 1/2" radius using this point as the center.
3. Draw vertical lines down from the sides of the larger arcs and connect them to the bottom of the smaller circle using gentle curves.
comment
Add Comment
Add Comment
