3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Sewing Organizer
Step 3Second step
Second step
Next place the materials with sewn pockets at the bottom side of the pegboards, and the batting in between. Measure 5" down from the top middle: make a little hole with scissors and place a 1" nut and secure it with a bolt in the back side: here you can hang a clock (in this case, also possible a calendar, monthly planner, painting)
Next step is to start putting bolts and nuts together through material to create the spools holder.
Measure from the top 14-1/2" down; you start from right to left placing a 3" bolt with nut, fender washer in between and tighten up with a nut on the back; screw the nuts as tight as possible; the holes are already in ( the pegboard) but you have to make a little hole in the material. Starting in order right to left you building the first row going down
Leave 3" space between the bolts and make 6 rows with the 3" bolts, and one last row with 2" bolts to fit the smaller spools( the 3" bolts also fit the smaller spools but it makes more comfortable with 2" bolts)
1 comment
Jul 6, 2008. 2:10 PMNneave says:
Wow what a great idea, thank you.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:saleyla
