Sewing a perfect 3-D corner (for a cube)
 by mdhaworth
Contest WinnerFeatured
I have always had trouble making tidy corners for 3-D sewing projects. Since I worked out this technique I thought I'd share; it works well on heavier fabrics and for projects like fabric baby blocks where it really shows if you fudge the corner.
Hope this tutorial is helpful; leave a comment if you have questions.
Melissa
http://underconstructionblog.typepad.com
Step 1: Cut out your fabric
In this example I'm making a cube so I cut out 6 identical squares of fabric but this technique works for any project where you need three pieces to intersect in a perfect 90 degree corner.
You'll also need a sewing machine.
(I also let my daughter decorate the fabric to make blocks for her cousin--this step is optional ;)
rcanovi brand says: Sep 21, 2011. 3:24 AM
Thank soooo much!!!!! It works like a bom :))
nklaewkla says: May 19, 2011. 2:25 AM
That is great !
Thank you ever so much for your kindness.
Easy understanding and well photo..
I made it.
Thanks again.
Joy. Chiangmai , Thailand.
momm says: Sep 17, 2008. 10:49 AM
Thanks alot for that info you make it look so simple;especilly with the photos
houseofdarkly says: Sep 12, 2008. 9:11 AM
I think I sort of had this idea when I was working on corners (and other tricky junctures), but I would always forget from one project to the next. (One always gets frustrated near the end and thinks it's time to swear the seams into submission; rarely works.) Thanks much for the writeup!
deregering says: Sep 11, 2008. 5:06 PM
Thank you, I might try it (again) now, with new hope!
jessyratfink says: Sep 9, 2008. 6:29 AM
This is great. I fought and fought with this when making my Robot plushie. Then again, I also took the lazy route and cute out a + and one extra square. :P
mdhaworth (author) in reply to jessyratfinkSep 9, 2008. 9:50 AM
Yep, that's what I had been trying to do, cut as few pieces as possible, but it always came out funky and this seems to work so much better!
canida says: Sep 8, 2008. 12:38 PM
Nicely explained!
Corners are hard.
pfirsch says: Sep 7, 2008. 12:31 PM
Thank you for sharing! This will definitely come in handy.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
