This only works with generation two touches that come in the hard plastic shell.
You'll need
- The Clear hard shell
- The USB cable
- The plastic cradle adapter
- Sand Paper
- Marker and masking tape
- Hot glue
- A drill/drill press or Dremel
Remove these ads by
Signing UpStep 1Mark where you want to cut and make the hole
Leave at least 2 mm around the edge so that the cradle will have something to sit on when you cut the hole
I used a Drill press to punch holes around the corners to keep them a bit round. I then used a dremel to cut the straight edges and then grind the hole into shape
4
comments
Add Comment
Add Comment
