3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Sexy computer prank
Sexy computer prank
Creates a Pop-up that won't go away!
Step 1Just go to notepad
Just go to notepad
Go to notepad (start>all programs>accessories>notepad) and type the following between the lines (if you can't read it, copy and paste)
dox= msgbox("The website you are trying to access (place name of dirty website) has been blocked by the administrator.",0+16+4098,"Restrictions")loop
the text inside the parenthesis should be replaced with any name of a porn site.
36 comments
May 20, 2011. 8:54 PMbdblock94 says:
is there a script to use that will open two others at the same time?
Jun 22, 2011. 6:34 AMSuper_Nerd says:
Sure look here! This one is designed to make errors, but you can modify error.vbs to whatever you want.
Jul 11, 2008. 8:07 AMlast_decoy says:
go to the task manager. either right click the bar at the bottom of the screen or: alt+control+del and kill the vb task. easy.
Nov 2, 2010. 5:13 PMMrCreator says:
it's CRTL ALT DELETE not alt control delete. just saying... ;)
Jan 25, 2009. 7:33 AMknocker says:
1) Play the chord (Ctrl+Alt+Del) to open the task manager. 2) Click on the "Processes" tab. 3) Click on "Image Name" to sort the list. 4) Scroll down to the process named "wscript.exe" and click on it. 5) Click the "End Process" button (or press the Delete key). 6) Click the "Yes" button. 7) Close Windows Task Manager.
Mar 22, 2010. 8:20 PMKing Julien says:
thanks a ton.
Mar 22, 2010. 8:21 PMKing Julien says:
no sarcasm
Sep 15, 2010. 5:33 PMunominame says:
now to only make this into a fork... Hmmm...
Jun 28, 2008. 11:30 PMQwertyuioLP says:
Could you add a timer?
Jul 16, 2010. 3:18 AMmichaelb958 says:
Of course! On a separate line before the do, add WScript.Sleep [delay], where [delay] is replaced with the number of seconds you want to delay it for multiplied by 1000! So, to wait 1 minute [60 seconds], it's WScript.Sleep 60000.
Apr 2, 2010. 7:04 PMexample555 says:
I did this at school on the teachers computer and she started swearing alout, it was halarious
Feb 19, 2010. 4:29 PMn3rdd says:
@ School. heheheh!
You're in big trouble mister!
Jun 28, 2008. 10:26 PMQwertyuioLP says:
Could you add in a timer?
May 14, 2009. 4:47 PMjimtran93 says:
yes u could... research it
Jul 7, 2008. 12:28 PMsnoopdoggsaju says:
how do u get it to go away?
read what Knocker said above
Nov 27, 2008. 11:55 AMskoolkid#69 says:
how do you take it off the screen it wont go away
May 14, 2009. 4:46 PMjimtran93 says:
read what knocker" said above
Jan 2, 2009. 1:50 PMdragonblue80 says:
Couldn't you make it go away by taking out the "loop" code in the script, then press "X" then it will go away?
no, because they won't let you save it while it is running.........
Apr 1, 2009. 4:44 PMMister nobodie says:
No, it doesn't work. it just says "ERROR: "loop" without "do" :(
May 14, 2009. 4:44 PMjimtran93 says:
that means u didn't have "do" in ur script
it should read:
do
loop
Mar 19, 2009. 12:28 PMjunits15 says:
it would be even cooler if you put it in the startup folder
Jan 13, 2009. 4:20 PMvolquete says:
i tried a test on my computer and it works really well! XD can't wait for computer lab!
Jan 12, 2009. 8:09 PMvolquete says:
gotta do this in school computer lab XD
Sep 4, 2008. 6:26 PMgeeklord says:
flash drive+school computer+pissed off teacher= AWESOMENESS!!!
Jan 12, 2009. 8:08 PMvolquete says:
XD
Oct 6, 2008. 4:10 PMgod_gave_knex_to_you says:
do i wanna know what you did?
Oct 7, 2008. 4:18 PMgeeklord says:
:D
Sep 4, 2008. 6:31 PMgeeklord says:
HOLY CRAP IT WORKS FLAWELEESLY!!!(until the teacher uses task manager, which might take a while :D) I LOVE YOU!!! jk
Aug 19, 2008. 10:50 AMkrazzyj says:
Ok a little improvement... give them IE then wait for the popup. They will think it is for REAL>...
Set WshShell = WScript.CreateObject("WScript.Shell")
WshShell.Run """C:\Program Files\Internet Explorer\iexplore.exe"""
WScript.Sleep 50000
do
x= msgbox("The website you are trying to access *** has been blocked by the administrator.",0+16+4098,"Restrictions")
loop
Jul 21, 2008. 1:39 AMcamel flag says:
omg that is so funny
Jul 9, 2008. 7:19 PMkicker109 says:
yeah how do you get it to go away
Jun 14, 2008. 11:48 AMAZIMUT says:
nice. I did it to my friend at his house while he went to the shops. When he got back he tried 2 show me somthin on youtube and he went bright red when the message came up!
Jun 3, 2008. 12:36 PMcomodore says:
HAHAHAHA!!! I like it, good prank! rate:*****
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:the guardians
