Remove these ads by
Signing UpStep 1Shadow Box with Splines, I made it at TechShop
s4s (surface four side) piece or of wood (length will vary on the size of your box)
smaller s4s 1/8 thick piece of wood used for the splines
2 ½ inch piece of ¾ ply wood (length will vary on the size of the box)
scrap block wood
Clamp (TechShop)
Tape Measure
Cord less drill and 2 screws (TechShop)
Table saw (TechShop)
Dado Blades (TechShop)
Chop Saw (TechShop)
random orbital sander (TechShop)
sand paper for the random orbital sander 80 120 150 220
wood glue
painters tape or masking tape
ban saw (TechShop)
Spine Jig
¼ thick backing board (Masonite)
¼ thick piece of glass
Point Drive with inserts
I think you'll find that the word is "Dado" not "Ditto" (Unless Ditto is some kind of brand name for the Dado cutter you use). Dado Head Cutters are not a universally available tool. They're not even legal here in the UK, because fitting and using them requires "modifying the tool in a manner deemed to be unsafe", i.e. Removing the Safety Guards.
There are of course other and possibly "better" methods, but it's results that count. Well Done!
Planes are generally faster, cleaner, do a better job, and are generally much more pleasant to work with.
They do, though, have a higher learning curve, both in using and in learning how to setup and sharpen.
