3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Shadow Sculptures!
Step 4Building the shadow
Building the shadow
Finally after all that set-up, you get to build the shadow!
This is actually easier than you may think. All it takes is filling in the perimeter you set-up earlier!
Some notes:
Picture 1
The cereal box has been torn on purpose. You should try to stray away from doing this too often, as it tends to be considered as "cheating". If you have no other options, you can resort to this, as in small parts it can be helpful and look pretty cool.
Picture 2
At times the pieces of junk that you use will need to be balanced in a certain position. This means that you will need them to be glued that way. But unfortunately, not all glues are instant. So you will need to hold it in place while it dries a bit.
2 comments
Dec 12, 2009. 4:09 PMstar2 says:
 it would be a cool trick to make someones shadod a wolf
Jul 22, 2007. 9:08 AMwhiteoakart says:
Hot melt glue would be my choice for an adhesive. It has nearly instant sticking power. If you are a hot melt connoisseur, like myself, you would use three different guns: low temp: quick set, relatively safe. for light weight items. Available at craft stores, grocery stores, and department stores. This is what your preschool teacher uses. high temp: industrial power. for heavy weight items. Will fry your skin off, so be careful. These guns are not easy to find. You must get them at a tool supply company. But they work great. medium temp: for everything else. You can find these at any hardware store. Or you could just use the medium temp, which is what reasonable people do.
Jul 25, 2007. 1:06 PMwhiteoakart says:
I don't mind. In fact I would be delighted. Isn't that what Instructables is all about, Sharing? Have a great day. I love this Instructable. I think my kids will really like trying it.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:TheJehosephat
