Shake-A-Can Generator
Introduction: Shake-A-Can Generator
Shake-A-Can Generator.
Make a simple generator that will help show how electricity is produced.
A generator works because the magnets are exciting the electrons in the coil. The magnet moving back and forth creates alternating current (AC).  That is the electrons are moving back and forth through the coils and the LED (light emitting diode).  The excited electrons passing through the LED lights the LED.
This idea for our first instructable came from Jonathan Hare at
Check out our website at
Step 1: Materials
35 mm film canister
Thin insulated copper wire*
Magnets that just fit in canister**
Scissors or wire cutters
*We used 30 guage magnet wire
**Neodymium magnets work best but we were able to get the light to turn on with ceramic magnets (much cheaper).
Step 2: Put Wire Into Can
Take 35mm film can and remove the lid. Place about (its not rocket science here) 3 inches of the wire into can and close the lid.
Step 3: Wind Wire
Wind on 500 to 1000 turns of thin, insulated copper wire. We recommend the 1000.
Cut from spool of wire.
1000 times wrapped around looks like this.
Step 4: Tape Wire Down
Add a layer of tape to keep the wire from unwinding.
Remember to leave about 3inches or so of wire free at each end.
Carefully take out the 3 inches of wire from inside the canister.
Step 5: Attach LED
Scrape off 1/2 inch of insulation from the ends of the wire (using sandpaper) and connect to the LED (it does not matter which leg of the LED goes with which wire).
Solder the connections if possible or wrap the exposed wire to the legs of the LED. Use some tape to secure the wire and LED to the bottom, top, or side of the can.
Step 6: Shake
Put magnet into the can and snap the lid back on.
Hold the can between thumb and forefinger at the two ends of the can with thumb or forefinger on the lid to stop it coming off!
The LED will light!!
  • Epilog Challenge 9
    Epilog Challenge 9
  • Pocket-Sized Contest
  • Science of Cooking
    Science of Cooking
how about adding capacitor which is holds electricity longer?
I made a few with students and some of them worked. But, over time they worked less and less. Is it just the construction or is there a possible reason for that. Pretty awesome when it does light up!
We found that students that make less wraps need more powerful magnets. We also found that flipping the magnets works to get the light to turn on again. If the magnets aren't straight the light wont turn on. We found that for some of the students, putting in a small piece of pvc pipe inside the film canister, helps keep the magnets from flipping on their side (if the magnets are to small for the canister).
We have students who have theirs from three years ago and have no problems. The kids really enjoy these and next years class is already looking forward to making theirs. :-)
Please let us know what helps!
Hello! Can I use copper wire that isn't insulated?
Oh no it's gonna be a short circuit, and your thousand turns will become a single shorted turn
I only have a 23 gauge wire. Is there any possible way I can do this or I really need a 30 gauge wire? I can't scrape half of the wire. :(
If you want the LED to stay on for longer periods of time (perhaps mins) than
I would like to suggest this YouTube link , ENJOY
Thanks so much for the video and comment. We have turned this into a flashlight using what we learned on and some guess work. Our problem is just what was mentioned in the video. Our capacitor would discharge to quickly and we had to shake the can often to recharge the capacitor. We were and are very happy we had it working at all but now we are getting excited about it staying on even longer. Thanks!
You're very welcome!
That video is another example of the endless fun of electronics and related hobbies.
Once again Thanks to it's Author Afrotechmods
its asuper and simple way to lit the LED with out any other device .simple to understand and prepare.
