Step 2Disassembling The Flashlight
1. Remove the bottom cap (the one with the wrist strap) from the flashlight by unscrewing it. (picture #2)
2. Remove the top cap along with the lens by unscrewing it. (picture #3)
3. Turn the flashlight over and remove the two screws using a small Phillips head screwdriver. (picture #4)
4. Now, remove the plastic cap previously held down by the two screws. Hold on to it though as we'll be putting it back very shortly. (picture #5)
5. Tilt the flashlight towards the LED end and the inside portion will slide right out. (picture #6)
6. Take the plastic cap you removed in mini-step 4 and screw it back into place at the bottom end of the flashlight. (picture #8)
7. Flip the flashlight over and use a small flat head screwdriver to pry the lens out. Once the lens has been released, remove it with your hand. (pictures #9 and #10)
What you have now is simply the inner core of the Hummer flashlight but this will be the canvas for the rest of the project. It also still works as a flashlight. Give it a try!
Add Comment
