Remove these ads by
Signing UpStep 1Parts
150 ft. 30 gauge enamel-coated magnet wire
4 1/8" rare earth magnets
4 rectifier diodes (IN4007 MIC)
Resistor (22 ohm)
White led
Switch
Some sort of small rechargeable batteries
Ballpoint pen
2 plastic washers or doodads
Tic-Tac container
Hot glue
Epoxy
Your "pompous and ill thought out" is not needed and is against the be nice policy. I bought a shake flashlight with a clear plastic handle, and the coil and magnet can be seen. The coil covers only the center third of the tube where the magnet slides. The magnet enters and exits the coil completely so that the most energy is transferred to the coil. If the magnet stays within the coil, the energy isn't as great as when it goes completely through the coil.
That being said, this flashlight takes a lot of shaking, and even then it doesn't produce much light, and the LED soon grows dim. It was not worth the money in my opinion. (I think it was twenty dollars.) There are better hand powered light; some have a squeeze handle, some have a crank.
