Shaker Style Rectangular Tapered Leg
This tutorial deals with modeling a rectangular shaker leg that is tapered on only two sides, with the taper starting a distance from one end. Loft will be used to create the tapered portion of the leg.
Extrude Cut with a taper could be used to create the tapered portion of the leg, but the taper angle is so shallow that it is impractical to set a template to manufacture the leg using the angle. Instead it is easier to manufacture the actual leg when using a distance to determine the dimensions of the bottom of the leg. Hence, this tutorial will create the leg using a dimension for the bottom of the leg.
Step 1Create New Part and Select Sketch Plane
Create a New Part, and Orient the View to Isometric.
Hover over the outline of the ZX Plane, and left click on the outline when it highlights in order to select the ZX-Plane on which to create the sketch. You could also select the ZX-Plane from the Design Explorer.
6 comments
Feb 7, 2007. 1:18 PMjltt says:
I'm new to this but I was wondering if this tapered leg could be made all at once with the loft feature. This would svae some steps if it could.. Thanks
Oct 19, 2006. 6:17 AMgigman says:
Thannk you very much for all the info woodknot! I will do that.
Oct 10, 2006. 2:56 PMgigman says:
I am intrested in learning this type of CAD, is there anywhere where I can get the basics or is there an order to the instructables in the CAD group? Do these tutorials build on each other? Thanks Gigman
Oct 10, 2006. 11:50 AMewilhelm says:
I think I fixed it. Let me know if something is still incorrect.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
20
Author:woodknot
I am an Engineering Technician with 15 years as a glorified government drafter. Another 5 years was spent drawing/programing for a company that had CNC machines. I taught AutoCAD at the local communit...
more »
