Extrude Cut with a taper could be used to create the tapered portion of the leg, but the taper angle is so shallow that it is impractical to set a template to manufacture the leg using the angle. Instead it is easier to manufacture the actual leg when using a distance to determine the dimensions of the bottom of the leg. Hence, this tutorial will create the leg using a dimension for the bottom of the leg.
Remove these ads by
Signing UpStep 1Create New Part and Select Sketch Plane
Hover over the outline of the ZX Plane, and left click on the outline when it highlights in order to select the ZX-Plane on which to create the sketch. You could also select the ZX-Plane from the Design Explorer.
6
comments
Add Comment
ewilhelm
says:
Add Comment
