You have to sneak up on this clock, hanging on the end of a slinky. If it sees you coming, it gets the shakes.
Step 1:
Using a Roberval balance arrangement (arms in the center), it doesn't matter where I place weights as long as the left and right side have a total equal weight.  Torque on the upright rod does change depending on where the weights are placed.
The clock, hanging on the slinky should be easy enough to read--but it's a slinky; it needs to bounce.  To make things a little more lively, I added a PIR module to detect anyone approaching from the front.  This operates a relay which turns on a shaker motor and gets the slinky moving.
The moving slinky/clock upsets my delicate balance on the arms.  Rather than the traditional solution of more weight on the left, longer base on the right, guy wire on the left (I try to break traditional thinking sometimes), I decided to turn on a fan on the left.  The blade "pulls" the system to the left--countering some of the wild flinging on the right.  I know, it's a waste of energy, but I wanted to try the concept.
astroboy907 says: Sep 25, 2011. 9:10 PM
Does it come with a zoom lense for looking at it from afar?
stevet47 says: Sep 25, 2011. 10:27 AM
Better hope your not in a hurry to check the time!
Kiteman says: Sep 25, 2011. 4:33 AM
Haha, you could use this same kit to make a Hallowe'en decoration that shakes when people go past.
jeff-o says: Sep 24, 2011. 10:22 PM
Ridiculous, complicated, silly, and totally over the top.
I LOVE IT!!!
Mimikry in reply to jeff-oSep 25, 2011. 3:29 AM
exactly my thoughts :D
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
