Shape Color Recognizer - Intel Edison
Introduction: Shape Color Recognizer - Intel Edison
*** we have to add the final video and some photos of final exposition ***
This project is part of Intel Make It Challenge
Our team in Fablab develop a prototype to manage and subdivide bottle cups by shape and color. In this first try we separate by shape with a balistic separator and by color with a Intel Edison board and a webcam. The system use Cloud platform for stream bottle cup type, to organize a future recycle system in the local area of a town.
Our Team
  • Stefano Varano Stefanosky
  • Armando Federici
  • Rosario Uriselli
  • Francesco Luzio
Step 1: Video
Step 2: Why We Build This One
we create a documentation in Italian about the project that aim to help local communities
Step 3: Balistic Separator
The balistic separator is the first part of mechanical separation of the bottle cups.
Two perforated plates do the job of separation. The bottle cups flow in different direction so we can manage the separation
All insert in a wood box, laser cutted
  • Wood 4mm - 120cmX60cm
  • plexiglass 3mm or 4mm - 40cmX40cm
  • plexiglass , a little piece of 5mm
  • glue for wood
  • brushed dc motor
  • electric wire
  • 1m wood rod of 6mm
Cut the piece with a laser cutter CO2 , files cad in AI8 for cutting is attached here in this STEP.
mount the structure and put some glue for wood
in plexiglass 5mm cut the wheel and little piece to move the plates
the kerf of our laser was ok for fit the motor shaft
Step 4: Slide
slide to bring bottle cup in the color separator
Step 5: Color Separator - Mechanical
instruction for the mechanical
I draw the parts and the gears. For the gears I experimented this
Then in Illustrator I tranform the round gear in a linear gear, and to obtain the right combination, we try!
It works! File Cad attached
the motors are 2 stepper motor 5V with uln2003 Driver, in the video a demo movement made with Arduino board.
In final costruction we add some little piece of lexi to reduce the noise movement as you can see in the video.
Step 6: Color Separator : Electronics & Software
instruction for electronics
  • Install Intel Edison
  • update firmware
  • update package
  • follow istruction for mraa, python, opencv, numpy
  • write code for color recognizer
  • move the mechanical parts
  • connect to iotkit platform by Intel (
The Intel Edison it's a mini computer fanless with wifi onboard. Inside there is a linux based OS, Yocto. For starting with this prototyping board it's necessary install:
  • driver software
  • the Intel Edison Board Configuration Board
    • install driver
    • update firmware
    • wifi configuration
  • chose a IDE
The starting process is detailed here in Intel website
Step 7: Install Python Accessory
After Configuring driver, firmware and wifi we can start to update the repository where Yocto find some new libraries and software configurated for this distro Linux.
For our recognition system we need
  • Python
  • numpy
  • openCv
We follow the beginning of this guide (the CandyLocker project) so:
--------------------- NOTE ----------------------
from the software Intel Edison Board Configuration Board you get the ip of the board download Putty.exe to connect via SSH and look the image about putty
configure to connection type SSH, host root@IP_FINDED (ex. root@ ) port 22
be sure to be in the same wifi with Edison board and your pc both
SSH to your Intel® Edison and type the following command in the terminal:
# echo -e “src iot-devkit-i586\nsrc mraa-upm\nsrc > /etc/opkg/intel-iotdk.conf
# opkg update
# opkg upgrade
Install Python Libraries
Next, it’s time to install Numpy and OpenCV
Numpy is a python library for working with data. To install it, type the following command in the terminal:
# opkg install python-numpy
The newest version of system actually has OpenCV installed, but only with C++. Here we need a Python binding to get it working. To do this, type the following command in the terminal:
# opkg install python-opencv
while Edison is still downloading software seems that nothing happen, the cursor don't show some progress, so be sure of your wifi connection and be patient if you get some errors, check wifi connection with # ipconfig and # iwconfig to see the signal strenght (as we read here )
in windows to upload file on the board we use WinScp software it connect with SSH and seems a FTP software (look screenshot) we start to upload some python code to test the correct working (from example CandyLocker )
So connect a WebCam to the usb, and put the little switch on the Edison in the usb OTG mode
Reboot the entire system
WEBCAM PROBLEM if you encounter in a webcam problem look here
Step 8: Software of Color Recognition - Logic
The system of color recognition is based on python image elaboration.
we do a photo with webcam to a bottle cup, then crop the photo to read only pixels on the center of the image, then pass the RGB value in several condition range, to detect color we want. Then move the mechanical part to put the bottle cup in the correct exit . The system also interact with Cloud IotKit by Intel to upload the statistics.
We start from CandyLocker software to test the python and the webcam
We use Sublime text 2 as text editor
with WinSCP upload the file in /home/root/CandyLock
via Putty SSH launch first python script
# python /home/root/CandyLock/
the script produce a jpg image (attached in this step)
Step 9: Software of Color Recognition - Practice
algoritm, file attached in this step
  • wait some key pressed
  • take photo
  • crop a little photo in the center
  • calculate a square in the center of around 2000 pixels
  • get the RGB value
  • put in a range condition
  • detect color!
for determination of the color range i use a website
ang get the min and max of each R, G, B of this color nearby
Step 10: Software of Color Recognition - LCD
the Lcd isn't managed by mraa, so instead you have to use pyupm_i2clcd
import pyupm_i2clcd as lcd
# Initialize Jhd1313m1 at 0x3E (LCD_ADDRESS) and 0x62 (RGB_ADDRESS)
myLcd = lcd.Jhd1313m1(0, 0x3E, 0x62)
# Clear
# Green
myLcd.setColor(255, 255, 0)
# Zero the cursor
myLcd.setCursor(0,0) # the first number is the line, 0 is the first line
# write
Step 11: Software of Color Recognition - STEPPER Motor
so the system move in the right position the bottle cups
we chose 5V stepper motor
to move the motor directly by Edison board we follow this tutorial
but use python instead of js
Step 12: Software of Color Recognition - IotKit Cloud
Intel team are developing a very nice Cloud system
if you follow the guidelines will be ok. we don't have any issue.
we follow istruction on the slides from Baldassarri on Intel Community Team
from page 178
here the official tutorial
wiki of Api
to send data from Edison to Cloud we use this in python
import subprocess
and then in the algoritm
output = subprocess.check_output (["/usr/bin/iotkit-admin", "observation", "webcam1", str(coloreNum)])
output : is the string of response from the server Cloud
webcam1: is the name of the sensor, registered in Edison platform and in the iotkit platform
coloreNum: is a int variable, that has to bo be casted to string, to be send correctly
other important resource
Step 13: Common Issue
in someways Edison can finish memory and works very bad, so after your testing and programming phase do a first clean of the Yocto system memory. In this way: (screenshot)
# rm -rf /var/log/journal/*
# umount /etc/machine-id
# systemd-machine-id-setup
# rm -rf /var/log/journal/* # reboot
Step 14: Mounting for Maker Faire Rome 2016
the whole system mounted and running
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Pro Tips Challenge
      Pro Tips Challenge
    It looks good! Thanks for sharing. :)
