3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Shaping Small Parts from PVC
With a Pyrex measuring cup, a little water, a piece of PVC, and a microwave you can shape plastic pieces that enable you to do and make useful things.
WARNING: Our PYREX cups are several decades old and work well with high heat.  I just learned PYREX was sold to a company off-shore that uses a different composition for the glass, and it is prone to exploding violently under heat stresses that were no problem for the original PYREX.  It sometimes explodes as you are removing it from an oven.  (October 12, 2009)
Step 1From round to flat
From round to flat
Pictured is a half-round piece of PVC I had left over from another project. The flat square was made by cutting a piece from the half-round and heating it while the water in the Pyrex cup boiled in the microwave for two to three minutes. I removed the cup from the microwave and used the tongs to pull the PVC piece from the very hot water. The tongs also helped to unroll the softened PVC so I could place the piece of wood over it and hold it flat against the countertop until cooled and firm. In the absence of a good supply of Plexiglass, some PVC flattened with the aid of a microwave and some hot water offers some impromptu versatility.
26 comments
Oct 25, 2011. 1:35 PMjuiceman74 says:
Phil, Thank you so much for the interesting post (as usual).
Can you first expand the idea behind the Dremel holder?
I'm looking into creating my own Dremel press. Would you recommend any technique?
Also, I was just wondering, about the GPS ball; Wouldn't it make more sense to form a mold from the original, and then cast a new shape from that?
Keep it up,
God bless - O>
Jun 24, 2010. 8:07 AMb1u3f0x says:
You do understand PVC has lead in it right?
Jan 25, 2011. 7:14 PMMaddMann says:
Newer PVC (Poly Vinyl Chloride) is lead free, look for ROHS compliant materials. Typically PVC is only harmful if it burns up. Warming it, as you did, in water shouldn't cause any harmful vapors or smoke which is where the real danger is. Lead free or not, PVC smoke is very harmful! I have spent the past 30 years working in environments where PVC is heated to melting point and extruded into various shapes. Don't take my word though, do some research on ROHS compliance, and MSDS sheets for various types of PVC from manufacturers of it.
Be safe, and keep the nice instructables coming!
Aug 18, 2010. 6:32 PMstayputnik says:
Actually, PVC is typically only used to carry waste water *out* of the home (ABS is only used for this purpose too). Any lines that carry potable water will be made of copper (unless the plumbing is very old, in which case galvanized steel used to be used a long time ago). For lines that carry drinking water into appliances (like to feed your ice maker), those will be made of PEX (cross-linked polyethylene). Cool tip though... I'm going to try this out (using an old pan filled with water).
Feb 5, 2011. 3:21 PMjj.inc says:
I live out of town and we have our own well, it is newer and every drop of water in our house passes through PVC from the well to our blast tanks.
Jan 25, 2011. 7:24 PMMaddMann says:
Your summation of residential piping is not entirely accurate. PVC piping is routinely used for carrying potable water as well as DWV piping; the latter is typically "Schedule 40" piping. PEX tubing is also used for potable water, heating systems, and - thanks to its flexibilty - in under-floor radiant heat sytems (Which ROCK!). Older homes also used copper supply (usually with lead solder) and cast iron for DWV. REALLY older homes used cast iron for everything, some used lead for DWV.
Jan 13, 2010. 6:29 AMGoodluck says:
Another wonderful tip. I'm not yet sure what I'll use this for, but I'm sure I'll use it.
By the way, I'm sure you're familiar with the "burrs" that saw cutting pvc leaves behind. An excellent way to get rid of those is a rag dipped in acetone (finger nail polish remover). They wipe right off.
Oct 14, 2009. 3:30 PMcovey12 says:
yea, burning pvc emits a harmful gasses, not sure about melting itthough
Sep 15, 2009. 12:06 PMSeppuko says:
Phil, This is a great Instructable. I stumbled upon it for other reasons, but it suits the needs of a different project I had in mind but hadn't figured out how to do. Thanks for posting it. Out of curiosity, why do you microwave instead of using a pot of boiling water?
Jul 17, 2009. 7:22 PMnorthie says:
Not to be a devil's advocate but, isn't there a chemical in PVC that you would be exposing yourself to if you heat it?
Jul 18, 2009. 3:40 AMnorthie says:
Just be careful. You get mixed stories online. Some say it's safe, others say heavy metals leach out when heated and the vapors are have been linked to lung cancer. It might not be from being heated underwater though.
Jun 10, 2009. 6:57 AMycc2106 says:
Great tip! I'll definitely use it. Thanks!
Jun 9, 2009. 8:53 AMDavetech says:
This will similarly work with ABS black plastic pipe, although I heat it up in a toaster oven. I keep a close eye on it and check the material's temperature often with my infrared thermometer. It seems that 260 degrees F is when the ABS goes soft and pliable.
Jun 9, 2009. 9:04 AMDavetech says:
The 4" ABS pipe I used has 1/4" thick walls, so if you flatten it, you will have a very sturdy, weatherproof platform to mount projects on or whatever. Gorilla glue does a good job of joining ABS pieces but I have not tried it on PVC. It seems like PVC cement would do a good job in joining the squares to create your sphere.
Jun 9, 2009. 8:52 AMcolinlewis says:
Very useful technique with some practical applications. I have used PVC in a variety of uses, but never heat formed it. Regarding the epoxy, I would bet that a thin layer of the glue used to connect PVC pipe to its fittings would work well, I believe it dissolves part of the PVC itself forming a strong connection between the two pieces.
Jun 9, 2009. 5:37 AMrimar2000 says:
Great, Phil!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
476
Author:Phil B
I miss the days when magazines like Popular Mechanics had all sorts of DIY projects for making and repairing just about everything. I am enjoying posting things I have learned and done since I got my...
more »
