Step 1: Materials
• ½ yard of dark gray fleece
• ¼ yard of light gray fleece
• ¼ yard of light stretchy knit
• Black and White fleece or felt scraps
• A handful of stuffing
• patience
*You will need a machine, and all the tools/things that you need to operate it
Step 2: Cutting it all Out
Starting with the brim, just cut a rectangle of 6 inches by about 21 inches of dark gray fleece. Cut it on the fold. You will have to adjust the length so it fits you head, if you mess up this part, you'll have a lot of trouble later. (If in doubt, cut larger!)
Cut your brim in half lengthwise, so you have two skinny long rectangles. Fold one in half and place on clean table/counter space. (Pic 3) This will be your guide for cutting out the shark tail part.
Start with the top of the shark. I didn't have very much fleece, so I used a rectangle (about 7x12") And placed it diagnally on the brim. (Pic 3).
Now take a rectangle of light gray fleece (about 4x7") and place it in the area between the other two pieces. (pic 3)
Use chalk and trace a football-like shape with a shark tail in the end. (pic 4 and 5) You should have doubles of each piece.
For the lining, you can use the pattern (last pic) And cut 4 triangle pieces. You may have to enlarge it, Just do the math. My length along the bottom was 6 inches, x 4 is 24 inches. That sounds big but each seam takes off about ¾ an inch.
Cut a dorsal and 2 pectoral fins, 2 copies of each. You'll also need to cut eyes and about 40 little teeth, but you can figure that out later.
Step 3: Sewing the Shark together
Take the top of the shark, the dark gray part, and mark where the light gray meets it right below the tail. Insert the dorsal fin and pin in place. Sew the two pieces together, over the fin and around the tail, stopping where you marked.
Take your shark's underbelly, and sew the on the two light gray pieces together.
Now you have an underbelly and a back. Put them together and pin at the tail. Insert the pectoral fins about an inch from the bottom and pin. Then sew all the way around. You now have your shark body, ready to be made into a hat.
Step 4: Sewing on the Brim
Keeping the brim inside-out, put it on the right-side out shark body. (Like above) Scoot it up until bottom edges meet. Sew along the edge.
Once you get that finished, flip your brim down and admire. Try it on in the mirror to make sure it fits.
Step 5: Sewing the teeth in
I made my teeth ruffly an inch long and ½ wide. You could make them bigger, or make a couple layers of teeth. With just one slightly spaced apart row, I had 37 teeth.
To sew them in, start with your shark body right-side out and the second brim piece inside out. Put the brim over the other brim part. (Right sides together) Put a few teeth in and start sewing, stopping every couple teeth to add more.
If you did the strip way of teeth, just put the strip in between the two brim pieces, and sew keeping all three edges aligned.
Once you've finished, turn right-side out and trim any teeth that look too long. It is nice to have some variety though.
Step 6: Add the Eyes
Sew on the eyes, about 2 inches away from the side seams. I sewed the black circle on first so I wouldn't have to change my thread an extra time. I doesn't really matter which order you do it in, just remember to start with the right color thread.
After you get that done, you can sew a tiny speck of white in the corner of the eye. It gives it a lot more character and doesn't make it look so flat.
Step 7: Adding the Lining
Turn right side out when finished. You can stuff the tail with a bit of stuffing, I think it makes it look fuller and rounder, giving it a nice shape. Don't forget to stitch up the hole!
Now, all that's left is to go enjoy your hat!!
I love seeing pictures! Share your picture and win a patch!
Visit Our Store »
Go Pro Today »
Unfortunately the one I made is just a little too small for my head, even though I tried to make it bigger. I'm going to make another and gift this one to a friend :D
Given that it's finally winter over here, we took the opportunity of the snow to give the hats a good "field test". They passed, hands down.
Here a picture of both sharks, eating the ladies, while I am trying not to look like I am posing for the camera :p
The kids love 'em, too, so actually thank YOU for the marvellous design and the idea!
I'm going to have to make a few and wear them as though they're eating each other.
But I would love to see your 2-dorsal fined shark! :P
