Sharpen a Push Reel Mower
Introduction: Sharpen a Push Reel Mower
Easier than it looks -- in fact looking at the pictures I am having trouble figuring out exactly what I did.... however it did work, so here we go!
Here is a video of the mower cutting grass once it is all sharp.
Step 1: Basics
A push reel mower is like scissors, except one blade is fixed and the other blade is on a reel.
The blades make a spiral so they are only cutting in one small spot at a time.
Here are the basic steps:
  1. Make it so the blades rotate the wrong way
  2. Put grinding compound on the blades, this makes the blades into there own sharpening stones
  3. Push the mower around until it is easy, this is called lapping (maybe reverse lapping...)
  4. Wash off the grinding compound
  5. Make the blades so they go the right way again
  6. Mow the lawn
Step 2: Take Off the Wheels
Step 3: Take Out the Gears
Step 4: Swap the Gears
Put the left gear on the right side and the right gear on the left side.
Now it will run backwards.
Step 5: Put the Wheels Back On
Step 6: Adjust the Fixed Blade
The blade that is fixed (not on the reel) can be positioned by adjusting two screws.
You want to make it so the fixed blade is touching the reel blades, so that it is hard to rotate the blades (but not impossible).
Step 7: Apply Grinding Compound
Putting valve grinding compound on the blades makes them into their own sharpening stones.  The blades will sharpen each other, eventually they will both be sharp and fit together perfectly.
They have this at auto parts stores and on amazon: Valve Grinding Compound
Step 8: Push the Mower Backwards
Pushing the mower backwards will now sharpen the blades.  Push the mower until it the reel is moving easily, then adjust the screws on the fixed blade so that it is is hard to push the mower.  Now push the mower until it is easy, again.  You want to repeat this until the blades are shiny all the way across. Video:
Step 9: This Is What It Looks Like Sharp
Step 10: Wash Off the Grit With Water
As the blade gets sharper you can start to wash off the grit with water.  This makes the blade easier to turn.  You also want all the grinding compound to be gone by the time you are  done.
Step 11: Take Off the Wheels, Again
Step 12: Swap the Gears, Again
Put the gears back on the correct sides.  So that the mower will go forwards.
Step 13: Put the Wheels Back On, the Last Time
    • Paper Contest 2018
      Paper Contest 2018
    • Science of Cooking
      Science of Cooking
    • Pro Tips Challenge
      Pro Tips Challenge
    Why would you want the lawn mower run back wards. I need to get my blades sharpen and I can’t do it. Also how can I cut the tall grass after you mow the grass.
    Worked like a charm! The compound only cost $4 at the auto store and I can probably sharpen the blades 8 to 10 times with one tube of it.
    When you say make it so the blades are going in the wrong way, do you just flip the lawn mower over a push it?? Not sure.
    You have to flip the gears to the opposit side so you can push it backwards.
    Just wonder should the pin be swaped too. How are the pins to be positioned? Can you illustrate further with photos or scatches. Thanks.
    I just swapped the gears and didnt touch the pins. I had no problems.
    I sharpened my recently restored Craftsman with the blade and gears swapped and tan it bacwards. You can actually feel tge blade moving more and mo r e freely. I purchased a reel mower sharpening kit with the grit in a jar. That old mower cuts grass like scissors now. Once it got sharpened i tightened it a bit more and added more grit to take off more uneven wear due to heavy rust for so many years. So I did this process twice. Switched tge gears and flipped the blade back around and replaced the tires and tried it out on Newspaper. It sliced the paper without ripping on evety area I tried. The mower cuts even thick patches of grass with ease.
    Excellent instructable! Thank you
    Excuse my ignorance but what is a grinding compound? What could i use? Thanks!
    Permatex 80037 Valve Grinding Compound, 3 oz.
