Remove these ads by
Signing Up
Remove these ads by
Signing Up
Remove these ads by
Signing Up
PDF Downloads
As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
Given the fineness of the mediums you are using I was interested in just how much difference the final polishing of the bevel made so I refinished the bevel on the chisel with stannic oxided slurry on an oiled paper lap. It turns out to be quite significant.[see image] This produces a very slight bull nosing of the bevel. Probably better to use the slurry on a steel lap.
Kind Regards,
DJH.
I was quite pleased with myself that the old chisel [Swedish c. 1910] I was restoring seemed to meet the end grain test till I took a look at my handy work under a microscope.
What appears to the unaided eye as a mirror finish can be deceptive! I still have much to learn. What look like chips out of the edge are in fact tiny corrosion pits on the flat of the blade.
DJH.
Kind regards,
David Hogg.
Any help Please?
In a way it make sense.
Thanks for this instructable that'll be really handy :)
It's funny how sometimes we get used to working with dull tools and don't realize what a difference a sharp blade makes.
For everything else I got used to sharp blades at a very young age. 20 years ago I thought I knew everything there was to know about sharpening too. Since then I've learned a thing or two though.
Today for instance I wouldn't consider a chisel edge fully sharpened unless it was stropped. Wire edges are for scrapers.
http://img.archiexpo.com/images_ae/photo-g/waterproof-rigid-polyisocyanurate-foam-and-bitumen-insulation-panel-for-roof-449951.jpg
A dull knife goes through that stuff like it is hot butter. A sharp knife sucks though. I've used both. I wouldn't have brought it up if it wasn't different.
I never saw anyone ever try to cut the stuff with a hand saw. Mostly because no one had a hand saw, and dull knives worked so well why would we use anything different?
http://www.fine-tools.com/G-applikationsflasche.html
I agree with mikeasaurus it's surprising how people can get used to dull tools.
I recall many years ago spending most of a Sunday getting a workmates chisels up to standard & another Sunday a week or two later teaching him how to keep them like it, he seldom used them but at least when he needed to they did the job properly.
I have always belived that any tool well looked after & maintained is far more useful than the most expensive one mistreated & neglected.
Any chance you will follow this up with one about maintaining your stones & wheel?
It is a long time of experiance and the result of many tries to find what is good or not.
I love to see someone who takes care for his tools and knows how to make them usable.
So far the best steel I've had the pleasure to sharpen is in some kitchen knives I own. Knives made by Henckels for a company named Hoffritz that were cyrogenically treated. I could cut a Japanese waterstone clean in half with one of those knives, and still slice a tomato paper thin after the fact.
Imagine trying to cut a waterstone in half with your knife if it had been left in the bottom of a damp drawer rattlling around with your spanners & hammers for a few years, I doubt you would have much luck.
I have a one inch chisel I bought about twenty years ago for about £1.20, I had left mine at home & needed one to trim around a door frame to fit some cables for an air conditioner, it ihas been well looked after & is still sitting in my workshop now, sure it does not hold it's edge as long as my higher quality ones but it does perform a more than adequate job & I still use it regularly.
The ones I mentioned previously I sharpened for my workmate were if my memory serves me made by Marples, not I will grant you the most supremely high quality available not equally they were not exactly rubbish & many people myself included have enjoyed using their Marples tools for many years; his ones howver had been kept in a plastic bag in the bottom of a tool box, three of then had NEVER been sharpened & the forth had a sloping cutting edge & a CONVEX!!! bevel.
I ask you this, if you had to use one or the other given the choice of using my £1.20 dirt cheap but honed & well maintained chisel or his much better quality & far more expensive but blunt & chipped Marples ones.
"Which would you choose?"
What I really hate about Japanese waterstones is they spall if my shop freezes. Something about water freezing in stones that isn't good you know?
How much is a good set of Japanese water stones?
