Introduction: Shelf Actions Figures of Donkey Kong and Mario Bros
My name is Emerson Pedroso, I am creator of the YouTube channel DIY Workshop.
In Workshop DIY today, we do this incredible shelf based on the phase of the first game Donkey Kong which appears for the first Time Super Mario Bros, the shelf is a little laborious, but the end result is worth every effort if you want to know how it was done follow the images above to see the video explaining in detail the construction:
The Channel DIY Workshop is the right place for those who like to learn how to build and cook creatively and easily sign up to our channel to receive updates of videos that will air every Friday, interspersed between the DIY Workshop and GEEK Cooking .
Contact advertising EXCLUSIVE: oficinadiyroo@gmail.com
Para acessar este tutorial em Português, acesse este link:
http://www.designoteca.com/designs/1557
Step 1:
Cut the templates according to the available sizes in the previous slide, do it with all parties, then sand them all
Step 2:
Assemble the parts using adhesive glue or wood glue, if you prefer to use small nails to strengthen the structure.
Step 3:
Pass the primer on all parts that have been cut, this will cause the black ink secure the best part, stay tuned to detail not missing anywhere without the primer.
Step 4:
To secure the shelves ready on the panel, use two brackets in 'L' small with the small screws still going to be left one end of Screw on the main base, to let smooth, use a file.
Step 5:
For mounting the shelves on the panel, follow the assembly drawing slide and if you need to use adhesive glue to help in fixing once assembled apply two coats of black spray over the whole piece already assembled.
Step 6:
To make the front panel finishing, cutting strips 1 cm eva Red 5mm thick, pasting and go over the top with the adhesive glue following the drawing below.
Step 7:
Finally, pass the press in finished stairways and then pass two hands country green ink on the play, then so is put on the shelf and fixed with the adhesive glue.
Step 8: Final Result
Enjoy this Instructable?
Soon we will post more projects in English to accompany you. Let us suggestions and comments for upcoming videos if they want the subtitled video, if you have enough requests I legendo :P Access our channel on youtube, besides workshops have a cooking table :D
https://www.youtube.com/channel/UCI-bK_5XZ7ybCk5u...
Thank you for your personal attention and even more! \o
