Shift Key Usb Drive (Custom Case)
Published
Introduction: Shift Key Usb Drive (Custom Case)
About: Just a Small Tinkerer ;)
My Old Usb Drive's Case was broken today so i thought to make a new custom case and there was also a Old Keyboard lying in my house's store room.
So,to make use of that and build a Shift Key Usb Drive.
Step 1: Getting the Things
We Will need a :-
1. Old Keyboard
2. Usb Drive with no Case
3. Epoxy (Mixing Type)
4. Flat-Head Skrewdriver
5. Plier ( forgot to mention in pic)
Step 2: Pull the Key Out of Keyboard
Fit the skrewdriver and pull out the key from keyboard.Be Careful not damage the key.
Step 3: Pull Out the Wire and Cleaning the Inside
Pull the wire from key.
Now, break that round thing with plier and other plastic which is inside.
Step 4: Mixing the Epoxy
Mix the Epoxy till it is fully black.
Just apply it as fastest as possible.
Otherwise if you go slow , it will get hard and it will be wasted and if you half-way appling epoxy to usb and key then it is worse.
Step 5: Put the Epoxy
First Put the Epoxy Acording the height you want your usb drive to be. Then Epoxy the remaning part.
It was a Hard time having a Flat surface at the end.
Step 6: Final Product
A Shiny and Good Looking Usb Drive.
Now Impress Your Friends Also By Making Custom Cases ;)
  • Woodworking Contest
    Woodworking Contest
  • Planter Challenge
    Planter Challenge
  • Oil Contest
    Oil Contest
4 Comments
I Used cutter but it gave me a rugged Surface.
razor blade for flatter surface while still pliable. I may use this one. thx
Very cool and simple design. Keep up the good work.
