loading
Step 1: Materials
Arduino UNO
Module Bluetooth HC-06
Smartphone with Android
Puente H - L293D
Motor 2x DC
Transitor 7809CT
Breadboard
Jumper Cables
Step 2: Arduino Circuit
Step 4: Arduino Code
int motor1Pin1 = 3; // pin 2 on L293D IC
int motor1Pin2 = 4; // pin 7 on L293D IC
int enable1Pin = 6; // pin 1 on L293D IC
int motor2Pin1 = 8; // pin 10 on L293D IC
int motor2Pin2 = 9; // pin 15 on L293D IC
int enable2Pin = 11; // pin 9 on L293D IC
int state;
int flag=0;        //makes sure that the serial only prints once the state
int stateStop=0;
void setup() {
    // sets the pins as outputs:
    pinMode(motor1Pin1, OUTPUT);
    pinMode(motor1Pin2, OUTPUT);
    pinMode(enable1Pin, OUTPUT);
    pinMode(motor2Pin1, OUTPUT);
    pinMode(motor2Pin2, OUTPUT);
    pinMode(enable2Pin, OUTPUT);
    // sets enable1Pin and enable2Pin high so that motor can turn on:
    digitalWrite(enable1Pin, HIGH);
    digitalWrite(enable2Pin, HIGH);
    // initialize serial communication at 9600 bits per second:
    Serial.begin(9600);
void loop() {
    //if some date is sent, reads it and saves in state
    if(Serial.available() > 0){
      state = Serial.read();
      flag=0;
    // if the state is '1' the DC motor will go forward
    if (state == '1') {
        digitalWrite(motor1Pin1, HIGH);
        digitalWrite(motor1Pin2, LOW);
        digitalWrite(motor2Pin1, LOW);
        digitalWrite(motor2Pin2, HIGH);
        if(flag == 0){
          Serial.println("Go Forward!");
          flag=1;
    // if the state is '2' the motor will turn left
    else if (state == '2') {
        digitalWrite(motor2Pin2, LOW);
        if(flag == 0){
          Serial.println("Turn LEFT");
          flag=1;
        delay(1500);
        state=3;
        stateStop=1;
    // if the state is '3' the motor will Stop
    else if (state == '3' || stateStop == 1) {
        digitalWrite(motor1Pin1, LOW);
        if(flag == 0){
          Serial.println("STOP!");
          flag=1;
        stateStop=0;
    // if the state is '4' the motor will turn right
    else if (state == '4') {
        if(flag == 0){
          Serial.println("Turn RIGHT");
          flag=1;
        delay(1500);
        state=3;
        stateStop=1;
    // if the state is '5' the motor will Reverse
    else if (state == '5') {
        digitalWrite(motor1Pin2, HIGH);
        digitalWrite(motor2Pin1, HIGH);
        if(flag == 0){
          Serial.println("Reverse!");
          flag=1;
    //For debugging purpose
    //Serial.println(state);
Step 6: Video
https://www.youtube.com/watch?v=WDkVVkuikwE&feature=youtu.be
 Creado por:
 - Macotela Bautista Sharon Lizeth
 - Torres Americano Mishelle
 - Flores Rojas Francisco
 - Delgado Monroy Omar
 - Roan Rendon Fernando Israel
 - Vera Bautista Jonathan Alejandro
<p>I want control program on Mobile</p>
<p>Nice, do you have a video of it in water?</p>
About This Instructable
1,386views
13favorites
License:
More by Jonathan Vera:Ship controled by bluetooth.
Add instructable to:
